Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 05-19-2022, 04:58 PM
remainanon remainanon is offline
Default Dolby Renderer sync issue with HDX/MTRX Studio
Hello gang -
Pro Tools working fine here, but if I set the output from the Atmos Renderer (3.7.2) to HDX, there is quiet but regular and persistent snapping, sounding very much like some kind of sync issue.
Hardware is:
Mac Pro 2019/12-core/96GB/10.15.7
Pro Tools 2022.4
Atmos renderer 3.7.2
The snaps happen when tone is generated in the renderer, or any other audio of course. Clean when audio is from Pro Tools direct to HDX>
The MTRX shares the HDX with an HDOMNI and 192/IO. Have not tried disconnecting those yet - a bit of a thing to do that.
Any ideas?
Old 05-19-2022, 04:59 PM
Default Re: Dolby Renderer sync issue with HDX/MTRX Studio
I should add that everything in the room, including all core drivers, is at 48K
Old 05-19-2022, 05:37 PM
BScout BScout is offline
are you on switch or sum in the Mon section of DADman? If on sum, change it to switch and only select the Audio Bridge source.
Old 05-19-2022, 05:53 PM
Thanks - tried - no change
Old 05-20-2022, 06:06 AM
creativecontrol's Avatar
What's your clocking scheme for all of your peripherals? You can access the Hardware Setup for your DigiLink peripherals for the CoreAudio driver by accessing AudioMIDISetup -> Configure Device. What is DADman set to for Clock Source, Adapt to, etc?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-21-2022, 09:22 AM
Hi Jeff -
I don't have a sync peripheral. I had not looked in AudioMIDISetup actually, other than to verify sample rate. Interestingly, the Configure Device route to the Hardware Setup window has HDX#1 Port 1 set to SYNC HD as Clock Master - and the menu is greyed out. Is that a hint of something?
Here are a couple of screencaps.
This was not happening in the room where the MTRX Studio is the only interface, so I guess one must suspect sync between the MTRX Studio here and the IFs on the other port.
Old 05-22-2022, 06:40 PM
Under Applications/Utilities/Audio MIDI Setup / try toggling the Clock Source as shown between the 2 sets of DigiLink ports.
https://www.dropbox.com/s/ty1tb25em7...Clock.png?dl=0
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-24-2022, 02:32 PM
Hey Jeff -
Looks like that might have helped! Will report back after some more time with it
MTRX Studio HDX and Dolby Atmos Production Suite Goombot Pro Tools | MTRX & MTRX Studio 64 09-30-2021 01:02 AM
Dolby Renderer with HD Native PCIe card its2loud Post - Surround - Video 2 08-26-2021 06:18 AM
Dolby Renderer and Big Sur? LewisP Pro Tools 1 08-16-2021 07:31 AM
Dolby Atmos Renderer dropping out of record Goombot Avid Pro Mixing General Discussion 2 07-28-2021 05:44 AM
Dolby Atmos Renderer file naming Branko Post - Surround - Video 6 03-01-2020 01:43 AM
