I reformatted my g5 today, reinstalled tiger, updated to 10.4.2................
I install 6.9.2.......open a session, hit play, immediately a -6093 overload error, telling me to increase buffer size (this is an 8 stereo track 24bit 44.1khz session) so i create a new session, import an audio file, now ive got 1 stereo track, hit play, immediately the same error my buffers are set all the way up, cpu usage allowance set to 80%, everything else at default so now i install protools 7.....exact same results I reformat a second time........exact same results I try running the audio of 3 different harddisks, no luck My maching = dual 2ghz (2nd rev) 4gb ram digi002r keep in mind that this machine used to work fine all the way through 6.9.2 please help, i dont want to have to destroy g5 and 002r in complete frustration |
have you followed all the steps in the sticky Troubleshooting thread... and run Disk Utility to verify/repair permissions?
Rail
try disabling save back up copies. It worked for me. Could be a little bug.
I'm having the same issues. Although I found that putting the computer usage at 90% or below actually helps, even though it should be the other way around. I don't think its an issue of not having enough resources but an issue with this first version of 7.0 le instead. And yes I went through the troubleshooting and repaired permissions a few times, that is not the issue here.
Pt 9.0.3 - Digi002R - Imac Dual 3.06 - 8GB RAM - Snow Leopard 10.6.8 - OWC Mercury Elite Pro HD - Akai MPK49 |
Pro Tools 11.1.2 HD completely unusable today | jonmichaels74 | Pro Tools 11 | 2 | 02-07-2014 11:43 AM |
Will my UA TDM plugins be unusable in PT 7.2? | OD | Pro Tools TDM Systems (Mac) | 10 | 03-10-2011 01:42 AM |
Workspace Unusable STILL | John Mad Anthony | Pro Tools TDM Systems (Mac) | 33 | 07-29-2009 09:50 AM |
Quad g5 and 002 almost unusable | shanestt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 26 | 03-14-2007 08:23 AM |
PT 6.02 SLUGGISH AND UNUSABLE | Skaberlakestudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 06-23-2003 01:15 AM |
