PT 2022.5 - sluggish GUI
I have my 5.1 with OpenCore and NVIDIA K5000, 3 Screens HD working...under BigSur. 2021.3 worked really fine, graphics wise, also in that SystemConfig. the last Updates were really awful... also actual Version produces bucking, I had also a Radeon 580 here to check, if the graphic card is the problem... no, it was not, and as 2021.3 worked fine on the same System, it seems to be a thing of PT... Ah and sure, I trashed preferences etc, also when changing GraphicCard... I know, it was in older threads, but anyone the same impression on this version..? Best Chris Last edited by ChrisSimon; 05-31-2022 at 05:32 AM. |
Re: PT 2022.5 - sluggish GUI
Zero system info makes it pretty hard to help.
https://duc.avid.com/showthread.php?t=300050 |
Sorry, I thought, it would stand in my signature...
MacPro 5.1, 64 GB RAM, MacOS BigSur, OpenCore Patch 0.4.5, Samsung SSD StartVolume, NVIDIA K5000 Mac GPU, HDX 1, ProTools 202x.xx |
It is running pretty snappy here. My first guess is a plugin compatibility issue. Try moving all your plugins into the unused folder, relaunch Protools, and see if the GUI runs better. If so, start moving plugins in one or a few at a time and relaunching Protools in between until you find one or more plugins that are causing the slowdown. Check with the plugin manufacturer to see if there is an update that works with Protools 2022.4 or 2022.5 and Big Sur. If not, you might need to skip that plugin or find an alternative plugin that does something similar.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
No, has nothing to do with critical plug ins, already checked...
Sluggish feel was also in there versions before... Last Version which worked snappy was 2021.3 - with same Setup |
Since many folks report pretty good GUI speeds in Protools 2022.5, there must be something else causing this on your system. I wonder if others using OpenCore can report their GUI performance results. I know you said you checked plugins. Was that just checking the manufacturers website or did you actually move them out to the unused folder and relaunch to see? If all else fails, it might be time to do a fresh clean install of the OS and Protools and test BEFORE installing any third party plugins.
Obsidian Dragon
We are not seeing any graphics slowdown on either of our iMacs with PT Studio 2022.5, in fact, we are seeing a little better graphics performance with PT Studio 2022.5 on our 2020 iMac.
Luna 1.5.5, Logic Pro 10.8.1/Logic Pro 10.7.9, Cubase Pro 13.0.30, Studio One Pro 6.6, Pro Tools Studio 2024.3.1, PreSonus Quantum 2, UA-2 Software 11.2, UA Apollo 8, UA Apollo Twin Mk 2 (2), UAD-2 Thunderbolt Satellite Quad (2), Fractal Axe Fx III Mk. II Turbo FW 25, USB FW 1.15 and Axe-Edit III 1.13.19, Studio A: Apple iMac 2020, i7 8-core 3.8 GHz, 64 GB RAM, 1 TB SSD, RP5700XT GPU, 10 Gb/s Ethernet, MacOS Ventura 13.6.6. Studio B: Apple iMac 2015, i7 4-core 4 GHz, 64 GB RAM, 1 TB SSD, RP395X GPU, 1 Gb/s Ethernet, MacOS Monterey 12.7.1. |
Well, I double-checked, removing all non Avid PlugIns, no difference...
still cursor line stuttering, when you have some tracks on, all DSP, non VI. Same Session under 2021.3.1 - no problem... By the way, BigSur was installed clean and also ProTools. Never make upgrades from oder systems... Question to all OpenCore Users... anyone a clue? It has nothing to do with the GPU, as I had a Radeon 580 here to check that... Strange... Will try to install Monterey on a new volume... |
I wonder if it is something unique to 5,1 Mac pro’s. I’ve been running into many gui issues, especially sluggishness with several of the latest pt releases. I have a 580 card as well.
Ej |
I've had GUI issues with 6,1 for a long time. Only with certain apps/plugs though.
Pt 2022.5? | Raggi | Pro Tools | 47 | 06-16-2022 03:49 PM |
2022.4 bugs? | Soundworks UK | Pro Tools | 8 | 05-07-2022 06:18 AM |
D-Command with 2022.4 | Third Eye Studios | ICON & C|24 | 14 | 05-06-2022 08:29 PM |
