Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2021
Old 07-28-2021, 12:42 PM
NateAlexander NateAlexander is offline
Default Inverted Piano Roll in 2021.6 ::FACEPALM::
I'm not sure exactly when this happened, I don't recall it being like this ever except with certain colors but at least in 2021.6 the dark keys on the piano roll are light/colored in the background and the white keys are black/grey
and it's not just dark mode btw
Old 07-28-2021, 01:26 PM
massivekerry massivekerry is offline
Default Re: Inverted Piano Roll in 2021.6 ::FACEPALM::
There is a sweet spot in the "Background" shade slider that gets it... better. It's still a problem if you only open one track in the MIDI Editor. The highlighted area is inverted. I always have a blank MIDI track now that I can also select when I'm editing MIDI from another track, and that "normalizes" the black key/white key balance.
But yeah, big issue Avid, for those of us who use MIDI regularly. Just give the MIDI Editor separate color controls.
Kerry Smith
http://apothekerry.com
12-core 3.46GHz Cheese Grater, 64GB RAM, HD | Native, HD I/O
Old 07-28-2021, 03:02 PM
K Roche's Avatar
K Roche K Roche is offline
Great tip thanks
System :
Avid Carbon interface , PT Ultimate 2021.6 .....Mid 2020 iMac 27" 3.8GHz 8-core i7 10th Gen processor,,128GB 2666MHz DDR4 memory,,2TB SSD storage,,Radeon Pro 5700 XT with 16GB of GDDR6 memory,, on Catalina 10.15.7
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
Old 07-28-2021, 06:05 PM
hmm that trick did not work for me, still inverted when I select two MIDI tracks
it's so dumb though
one of a few things that make me wonder if any musicians work at AVID
Old 07-28-2021, 06:34 PM
It looks fine on my rig. I suggest 2 things might be worth a try:
1-update graphics driver
2-mess with brightness settings on your monitor(not too long ago, Melodyne acted as you describe where every note lane looked exactly the same. Adjusting the monitor brightness solved the issue for me)
Old 07-28-2021, 09:32 PM
Dave, I'm on a Mac. The Graphics drivers are built-in and the Brightness is pretty optimal. It's not that.
it's so dumb though
Nate, that's odd. I am posting some Screenshots here, to illustrate the things that I perceive as problems with this piano-roll color inversion, and how I've been dealing with it for now. It definitely feels like a bit of whack-a-mole tho.
File Type: jpg 02- 1 Instr Track + 1 empty Instr Track.jpg (39.5 KB, 0 views)
File Type: jpg 05 - Timeline brightness Normal-for me.jpg (36.8 KB, 0 views)
Kerry Smith
Last edited by massivekerry; 07-28-2021 at 09:36 PM. Reason: PNG files uploaded as JPEG and resolution was borked.
Old 07-28-2021, 11:47 PM
moshuajusic moshuajusic is offline
It looks kinda like Logic. What's the problem?
In all seriousness, is this dark mode? I'm still on 2019.
Old 07-29-2021, 11:53 AM
oh hey kerry didn't realize that was you haha
yeah so you're actually onto something with the color palette, timeline brightness inverts the piano roll depending on which side of 50 you're on
unfortunately bringing background brightness down so much make contexts windows SO dark! at least on my machine with my card/monitors. i'll just have to live with it for now
Old 07-29-2021, 12:20 PM
Does this only happen in "dark" mode? Does switching to "classic" mode fix the issue?
Obsidian Dragon
MacBookPro14,3 - Intel Core i7 3.1 GHz, 16 GB
MacOS 11.6 running Protools 2021.7
Old 07-29-2021, 02:28 PM
As some of you know I'm one of those that did major tweaks to the ptcolors.txt file and sent the file out to people here so I'm very interested in this situation. I have four different versions of PT on my machine (2019.6 2020.12, 2021,3,1 and 2021.6). PT 2020.12 looked okay here. 2021.3.1 has the problem.
There's a tweak I did that I don't think everyone has and that was to have the lines in the MIDI editor correspond to the key color. That is the white keys would have lines in the editor that were light and the black keys would have lines that were dark color. And it was fairly distinct. Something has happened in 2021.6 that's messed with this and as someone said it also depends on track color to some extent.
Give me some time to see if I can figure out what has to change. It'll be a couple of days.
Jack
QAPLA!
Tiny piano roll nyjdams macOS 5 12-03-2017 12:48 PM
piano roll / keyboard SupreGlu Pro Tools 10 4 10-28-2015 09:10 AM
Piano Roll ? cubs Pro Tools 10 1 01-01-2013 04:49 PM
Notes off screen in piano roll sepugaza MIDI 6 04-04-2006 09:46 PM
piano roll in midi track pietervd Tips & Tricks 2 02-24-2006 07:10 PM
