Old 07-26-2001, 09:47 PM
Blake Henderson Blake Henderson is offline
Default pro tools app. crashes when closing session
When I close pro tools or even just a session, I receive an error message in the finder.
"error type 2" "unexpectedly quit"
Dae is left on and when I close it i get the message:
"Appz still using the dae engine"
the error type 2 is normally a memory problem.
If I was using too many plug-ins, i would get the "running out of CPU power" message before something like this would happen. Right?
Has anyone experienced this problem?
Any advice would be greatly appreciated!!
I'm sick of these problems!
Blake
Clumsy Congregation
Old 07-26-2001, 10:07 PM
Chompers Chompers is offline
Default Re: pro tools app. crashes when closing session
trash the "digi set up" preference.
Restart..move on..
Old 07-26-2001, 10:18 PM
Thanks chopper. But it didn't work.
Only two sessions have this problem. Both are using "GRM tools"
"shuffler"
is that a clue for anyone?
Clumsy Congregation
Old 07-26-2001, 10:55 PM
bassmac bassmac is offline
I had a similar problem the other day that took several hours to troubleshoot. When I closed a session, the finder would quit and the entire system would freeze.
Usually when something works fine on day and not the next, it's most likely a corrupted preference file. In my case it was a Kensington trackball pref file. For some reason it goes crazy from time to time.
Typically I discovered this after doing every troubleshooting method known to mankind [img]images/icons/rolleyes.gif[/img]
Old 07-27-2001, 07:29 AM
DigiTechSupt's Avatar
Blake,
-Can you confirm that only sessions with GRM Tools' Shuffler cause the Type 2 error? Are there any other variables common to these sessions?
-Are you launching from a session template?
Brent
Avid Audio Tech Support
Support FAQ
Old 07-27-2001, 04:22 PM
Michael Cottrell Michael Cottrell is offline
This happened to me when I adjusted my DAE Playback Buffer to max. At a DUC member recommendation. It stopped happening when I put it back to default.
Not sure if that will help. Check it out. [img]images/icons/wink.gif[/img]
PT 10.3.8 Crashes after closing session drvibb Pro Tools 10 2 03-20-2014 03:17 PM
Crashes when (exiting/closing a session) louieshowers Windows 38 11-16-2013 06:17 AM
PT HD 7.4 crashes when closing a session deardaddy Post - Surround - Video 10 05-21-2009 03:01 PM
Closing one session crashes PT every time digidesigner Pro Tools TDM Systems (Mac) 13 03-23-2009 04:31 AM
Crashes when closing session Pro tools 7.0 Drive 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-07-2006 01:34 AM
