Old 09-23-2021, 12:16 PM
Germainbf Germainbf is offline
Default Error Messages
Hi everyone,
I'm new using Pro Tools and I have two problems:
1) I Can't open files in protools because it appear error messages:
No se ha podido completar su solicitud por el siguiente motivo: El parámetro no es correcto. (87) i:\OneDrive\Documentos\prueba5\prueba5.ptx
No se ha podido completar el comando Abrir sesión... porque memoria insuficiente (-108)
Infracción de acceso, no se puede leer la ubicación: 0x0000000000000000
Maybe some controller is wrong?, It worked well before install Pro Tools drivers, can anyone help me?
2) I have 4k screen and my Pro Tools window is too small, how can I make it larger?
Thanks to all
Germain
Old 09-23-2021, 12:47 PM
Default Re: Error Messages
If it worked before installing a driver, I would start by uninstalling that driver. Next, its tough to offer any advice with almost zero information on the setup. Re the 4K screen, I would set screen resolution to 1920x1080. That worked fine here when I was using a 43" 4K TV as my main screen(Pro Tools is still not optimized for 4K screens). You might get better advice by telling us what size the screen is(example, a 32" running 4K would make everything too small).
Old 09-24-2021, 10:22 AM
Dave,
Thank You so much, I had to re-install Pro Tools in my Computer and It Work. I had to reduce my Screen resolution and it works too.
Thanks...
Old 09-24-2021, 11:19 AM
Various error messages RossWooldridge Windows 15 06-06-2018 10:34 AM
Many different error messages, Pro Tools aborting or unable to click messages off riffmachine Pro Tools M-Powered (Win) 5 10-05-2010 04:15 AM
PLEASE HELP -Error Messages session48 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-19-2005 06:06 PM
DAE ERROR MESSAGES burgundyman Digidesign Hardware & Software 2 08-08-2002 12:50 AM
Error messages kevthebass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-21-2002 12:16 AM
