Anybody using PT12 on 2011-2012 IMAC?
Hello,
I have a 3.4 GHz Intel I7 IMAC, from late 2011. I am considering upgrading from PT 10 to PT 12. The computer isn't offocially supported, but the specs seem to be fine. Curious to know if anyone has any experience one way or the other. Thanks Ian |
Re: Anybody using PT12 on 2011-2012 IMAC?
I would expect a performance/stability improvement based on my experience with an older i5, when upgrading to PT11/12 ... and you can take advantage of lots of RAM if you have it - this will help significantly with bigger sessions but particularly because you can now use disk cache :)
FWIW, I'm running a mid-2012 Macbook Pro with Pro Tools 12.1 on OSX 10.8.5...No issues to speak of. I cannot vouch for later operating systems or versions of Pro Tools beyond 12.1 (it seems people are having issues with both.)
I am running PT 12.4 on El Capitan on a Mid 2011 iMac i7, 12GB RAM.
Seems to be working fine for me so far- -dj
iMAC 3.2GHz 6-core i7 250GB SSD (internal) 1TB SSD (external) 16GB RAM OSX 10.14.5 PT 2019.10 (last one) Waves Gold/RenMaxx v11 iZotope Ozone 8 Focusrite Clarett 8Pre Nord Stage 3 Nord Lead A1 DSI Mopho X4 |
Same here. 27" mid 2011 i7 16gb. Works great with RME fireface 800.
Mid 2010 here, 4 gig of ram, full band sessions seven days a week. Works great! Not much in the way of VIs though.
Protools Studio 24.3, 2018 Mac Mini, Core I5 6 core, 16Gb ram, Sonoma 14.4, Focusrite Clarett+ 8pre, Focusrite Octopre. Last edited by GeoffLee; 03-27-2016 at 01:52 AM. |
Thanks guys! It seemed like it should be good, but i always balk a little when i look at the hardware requirements, and my comp is not listed
Though it is not at all my main machine, I have a mid 2010 iMac 21.5" i3 (yes, you read that right - i3) dual processor with an SSD boot drive and 16 GB of RAM that runs the latest version of PT 12 just fine. Sure it won't be as fast to render some effects or offline bounce, but it still runs PT for basic and some even complex session work just fine.
If it had a standard platter hard drive, it might not be as snappy, but even with the "unsupported" i3 processor, it does indeed work. So I think your machine should work fine. Of course, remember that the video engine doesn't work with less than 8 GB of installed RAM. |
hi ian, have the same exact comp (16G) in my home studio,
running dual install of hd10.3.10 an hd12.4 on 10.8.5, doing dense edit/mix sessions, without a single crash yet from 12; in fact can create mixes on the I7 that bring our hd6 system on a mac pro (back at the studio), to it's knees, and end up having to kill some processing… e
ihatetyping |
2011 MBP - PT12, crackling/pops at 64 buffer setting | SixChurchStreet | macOS | 3 | 02-14-2016 05:11 AM |
Comparing a 2012 Mac Pro 3.33 GHz-6 core to the new iMac 5K | Imagine | Pro Tools 11 | 1 | 10-30-2014 03:04 PM |
Mac Mini 2011/2012 ProTools and CPU heat issues | propower | macOS | 24 | 11-28-2012 05:12 PM |
iMac 2011 | apples | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-24-2012 06:56 PM |
iMac 2011 & Mbox2Pro | groovesong | macOS | 1 | 09-23-2011 09:21 AM |
