Old 10-17-2014, 12:38 PM
Fezzler Fezzler is offline
Default Cheapest Upgrade Path for Improved PT LE 8 Recording
Up front, I will confess I fear professional recording engineers and enthusiasts will hate this post. But I am a home hobbyist, so be mindful of that.
I have the Eleven Rack with expansion pack. I use Pro Tools LE 8.05 on a Win7 Home Premium PC, 32-bit.
My computer is an Intel Core 2 Duo E6400, DC 2.13 GHz, 1066 MHz front side bus, Socket 775, Intel 945G Chipset, Asus Micro ATX Motherboard (Leonite-GL8e).
I have 4gb RAM on mobo; C-drive: SATA 250gig 5400rpm; E-drive: SATA 250gig 5400rp; L-drive 7200rpm firewire 800 for recording. Separate graphics card with 2gig memory.
I have made all of the recommended optimizations for Pro Tools LE 8.05 (or most). Most of my settings are defaults in Pro Tools. I adjust buffers as needed when recording vs mixing.
I'm happy with PTLE 8. I may upgrade both my computer and PT someday, but right now LE is fine and money is tight.
Given my satisfaction with LE and use of the 11R and firewire drive, what are some options for perhaps improving my LE performance on the cheap side? For example - will converting my C: drive to SSD make a difference? Get a "new" used PC or even a Mac (laptop or Mini)? New used pc, what is my most affordable option?
What would you do, beyond saving for PT and computer complete upgrade?
If this is totally ridiculous path, let me know. But, if I'm happy with LE, why not leverage the improved performance and lower cost of used technology for another 18-24 months?
What am I trying to solve for? PT LE hangs sometimes after a track is printed; or some heavy editing; or switching back and forth from 11R setting; or using VSTi like Boom or Structure or Xpand. So I am assuming a little more horsepower will eliminate that inconvenience and workflow.
Old 10-17-2014, 02:00 PM
mjslakeridge's Avatar
mjslakeridge mjslakeridge is offline
Default Re: Cheapest Upgrade Path for Improved PT LE 8 Recording
What is your CPU utilization when running a session with lots of tracks and plugins? I was using a Core2Duo e-4400 with LE up until a year or so ago with no problems. I would guess the problems with the VI's may be due to the speed of your C and E drives-only 5,400 rpms. With SSD prices really dropping, you may consider getting one for your operating system and sample libraries. I think many on the forum recommend Samsung 840 Pro SSD's.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ
Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit.
Old 10-17-2014, 02:58 PM
Now that you mention it, I have been getting messages that CPU use is high. Once, PT didn't freeze but I couldn't play back even if I adjusted buffers. I use mostly PT plugins with some Steven Slate console emulators and mix bus emulations. On the track I couldn't play back, it was only like 8 tracks, mix of midi and audio.
Are you good at reading Sandra reports?
Old 10-17-2014, 03:06 PM
mesaone mesaone is offline
Grrrrrrr
Go with a 64-bit OS and pack in more RAM. As far as I know, your license key for Windows 7 will work for the 64 bit version. That brings up the question of whether an upgrade to 64 bit would be worthwhile, or are there other limiting factors that would render that upgrade moot, like fewer DIMM slots than needed, etc. I'm not qualified to speak on this particular matter.
Yes, it would help if you replaced your C: drive with a faster HDD (7200 RPM) or a SSD. This will show improvement across the board, not just with Pro Tools.
Beyond that, I think attempting to squeeze any more power out of what you have is a game of diminishing returns. Be mindful that the cost of computers is pretty low, all things considered... The "Silverbox" computer in my signature cost $950, not including the $200 in hard drive upgrades I performed after purchase.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 10-17-2014, 09:53 PM
You are right I suppose. I didn't know if an old Mac mini or post-Core Duo PC would fit the bill.
I just rechecked my Sandra Report, all hard drives are 7200rpm already.
I guess I'll make do until I'm ready for new pc and PT upgrade.
When I do go new I was eyeballing the Sweetwater Creation Station series. Or going Mac.
Old 10-17-2014, 10:04 PM
If you end up buying a pre-built PC with Pro Tools in mind, check out http://www.pro-tools-pc.com/
Old 10-18-2014, 12:36 AM
zedhed's Avatar
zedhed zedhed is offline
I agree the best option is to sit tight until you can afford a complete overhaul upgrade otherwise you're wasting money IMHO.
Too much blood in my drugstream
Gigabyte X99 SOC Force Mobo Bios vF6d
Intel Core i7 5930k socket 2011 v3 @ 3.50GHz
32GB DDR4 Crucial RAM
System: Samsung M.2NVME SSD 960 Evo
Record: Samsung M.2NVME SSD 960 Evo
Samples: Samsung SATAlll SSD 840 Pro
Storage: 2x Samsung SATAlll SSD 840 Pro
EVGA GeForce GTX 750 Graphics
PT 11HD (v11.3.2) Omni s/pdif w Eleven Rack
HD 96I/O
Win 10 Pro
Old 10-18-2014, 09:28 AM
2 more cents With a socket 775, you could likely find a used quad core cpu for dirt money. That plus Win7 64 bit and doubling the RAM might give the old beast a bit more grunt. There are 2 issues to consider. 1-each newer version of PT seems to need more horsepower, and 2-NONE of your current plugins will work in PT11 unless they have AAX 64 bit versions available(which MOST do, but you may need to pay some to get these updated versions). After that, since you have a working setup now, I would remove your system drive and install a fresh drive, and load everything from scratch. Starting with a "clean slate" is the best way to do a major upgrade Good luck with whatever you decide to do
Old 10-18-2014, 09:30 PM
Will my mobo CPU socket take a QC?
Old 10-19-2014, 09:26 AM
Check with the mobo manufacturer website(we don't know what you have). Bear in mind it might also require a BIOS update(not a huge deal if you are going to reload Windows anyway).
Cheapest way to upgrade from PT8 to PT10? luts macOS 4 01-16-2014 06:06 AM
cheapest way to upgrade from protools 8? james21789 Pro Tools 9 4 01-30-2012 07:58 PM
Cheapest Path to Mac? EarBud 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-24-2010 07:19 PM
Cheapest upgrade for 001 user? riffing 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-24-2008 02:40 PM
Has PT's mixer's audio path 'math' been improved in 5.1 or is that just a myth? Jules Pro Tools TDM Systems (Mac) 25 05-10-2001 12:05 AM
