Old 02-21-2007, 04:46 AM
Andi R Andi R is offline
Default SYNC I/O Macintosh serial cable - max. length?????
Hi all,
I need a 10 meter cable for the connection of the SYNC I/O to the Core Card.
Is there a max. lenght for this one? is it supported by DIGI?
has anyone done this?
I could not find any info about this in the manual or on the digi site, and there was only one post in here, that was not quite helpful...
so any info appreciated!!
Thanks, and have a nice day!
ReRecording Mixer & Venue D-Show Live Sound & Recording Engineer
www.audio-machinery.com
Old 02-26-2007, 01:17 PM
Default Re: SYNC I/O Macintosh serial cable - max. length?????
no one?
DIGI???
Old 02-26-2007, 02:58 PM
1511 1511 is offline
Hello. If you're referring to the Digilink Cable, I have a 50' one for sale, if you need it. I used this one from my core card to a 192 i/o with no problem. I don't think there is an issue with cable length. Here's a thread on Digilink Cable length:
http://duc.digidesign.com/showflat.p...v=#Post1015126
email me:
nns1511@comcast.net
Thanks,
Chas
Old 02-26-2007, 03:36 PM
thanks for your time,
but I am asking about the cable from the SYNC I/O to the Core Card.
not a Digi Link Cable.
Old 02-26-2007, 03:56 PM
CPettigrew CPettigrew is offline
You're probably okay with that long a cable; finding one might be tricky. In the old days I had longer throws of that kind of cable to printers and midi boxes. Shouldn't be a problem.
Craig
Old 02-26-2007, 04:41 PM
jeff markham's Avatar
jeff markham jeff markham is offline
hi,
i ordered a 25 foot cable and it doesn't work .. PT says that
it can't communicate with it. a shorter cable did work .. so i don't know the
max length .. all i know is that my 25 footer doesn't work.
jeff
Old 02-26-2007, 06:43 PM
Lee Blaske Lee Blaske is offline
I've seen a pretty wide range of quality in wire used for serial connections. If you're going to try going that long, you'd want to get the highest quality, thickest, shielded wire you can find.
Lee Blaske
Old 02-27-2007, 12:57 AM
Richard Barrie Richard Barrie is offline
Mac serial cables are wired as cross-over cables. A custom made pin for pin won't work. I have run Mac serial cables up to 30 Mtrs. but haven't tried long cables for the Sync I/O.
Old 02-27-2007, 11:08 AM
The Pin Lazout is stated in the Manual, so I know that.
Thanks for your info!
Old 02-27-2007, 11:10 AM
hi,
jeff
25 foot are 7.5 metres... so I guess 10 metres wont work also....
where did you buy your cable?
Thanks!!
SYNC HD Serial Cable JJC Pro Tools TDM Systems (Mac) 11 03-12-2016 04:38 PM
50' serial cable and Sync i/o AmericanCheese Pro Tools TDM Systems (Mac) 1 07-21-2009 04:16 PM
source for macintosh serial cable wildplum Pro Tools TDM Systems (Mac) 3 04-21-2008 06:19 AM
serial cable length? fdc MIDI 3 05-09-2001 05:42 PM
maximum serial cable length for Mac ? Shabbyroad General Discussion 1 10-06-2000 12:10 AM
