computer in other room...how long can cords be?
I'm in a new studio now where I could put my desk top computer in another room, about 10-12 feet from my desk ( to minimize noise). What is the procedure for dealing with the keyboard, mouse, monitor, and firewire cables?
Asus P5K Deluxe Pentium Q9550 @ 3.4 ghz Corsair 1066 RAM www.guyfi.com www.flystudiosmilwaukee.com |
Re: computer in other room...long cords?
Thanks Rail...so if I went with the 1000 (http://www.gefen.com/kvm/product.jsp?prod_id=2294) I'd use a USB mouse and keyboard, right?
Anybody else doing this sort of thing? I'm a little surprised at the cost
Right - do you have a digital (DVI) or a VGA monitor?
Rail
VGA, though I recently got a LG flat screen, I think I'm going to start using that, or maybe use 2. Sorry to be ignorant, but is the LG a VGA? It uses the same cable hook-up
If it uses the same connector it's probably analog (VGA)... You could buy a long well shielded VGA cable for about $80. Check the monitor's specs to be sure (you didn't mention the model number).
Rail
Hey guy.fi,
I've been doing this for years. What I use is a switchbox from when I switched between 2 computers using the same mouse,keyboard & monitor. The computer is about 12' from the 002R and in an adjacent room. I have 10' cables with standard computer connectors going from the computer to the switchbox - mouse(green), keyboard(purple) and VGA for the LCD's, and then the regular cables from the switchbox to peripherals. No USB stuff. Since I use 2 monitors, I use an extension cable(Belkin)for the 2nd monitor. Works like a charm. |
I found a 25' extension cable (monitor, keyboard, mouse) for $34. Do you guys see any inherent problems with this?
http://www.action-electronics.com/switchboxes.htm
Will I run into a problem with a 25' VGA, mouse/ keyboard cable
I don't think there will be a problem with the keyboard & mouse at that length, but not sure about the VGA. My extra VGA extension cable is only 10'.
What's their return policy if it doesn't work to your satisfaction? |
Like to move computer & drives to next room - cable length? | arthur s | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-13-2007 06:31 AM |
How far is your computer from your control room? | wiota | Pro Tools TDM Systems (Win) | 4 | 07-24-2005 07:50 AM |
How can I put the computer and hard drives in a machine room. | rodrigal | Pro Tools TDM Systems (Mac) | 6 | 08-27-2001 03:46 AM |
can I leave my computer on 4 long periods? | tross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-09-2001 05:25 AM |
Planning machine room for noisey computer / bit 3, advice please | Tips & Tricks | 16 | 07-16-2000 03:12 PM |
