Old 01-04-2007, 01:40 PM
KD11520 KD11520 is offline
Default Quiet PCs (Recording in same room as PC) Advice?
Hello PTLE PC Users
I need to upgrade my case (X-Infinity) or my fans and power supply to reduce the noise when recording with a mic. Has anybody achieved this? I am looking for best results first and economy second.
All help is always greatly appreciated. Thanx
Intel QX6850, 8GB Ram, Asus MB, Win 7 64 Bit. New Install of PT 9.0.6 with MBox 2 Pro.
Old 01-04-2007, 02:38 PM
Jeff_C Jeff_C is offline
Default Re: Quiet PCs (Recording in same room as PC) Advice?
Take a look at www.endpcnoise.com and www.quietpcusa.com for quiet cases and other parts. I record with my PC in the same room and these guys helped me get great results. Here are a few tips:
- Get a case like the Antec Sonata designed for low noise
- Add acoustic treatment inside the case to dampen noise
- Larger fans make less noise because they run lower RPM for the same air flow.
- Big CPU and Video Card coolers with more surface area are quieter
- Quiet and silent power supplies are available
Try to determine the sources of noise in your current setup. You could unplug fans, etc. to narrow it down. Don't forget hard disks - check them both idling and accessing data.
Jeff
Old 01-04-2007, 02:49 PM
Checked out both sites. Looks like a solution is un the near future! Thanks again!
Old 01-09-2007, 10:06 PM
sw rec sw rec is offline
89.95 (plus shipping) gets you an ANTEC SOLO case from www. mwave.com, just bought one, check out my response under subject "QUIET CASES".
Old 01-10-2007, 07:32 PM
outoftune outoftune is offline
an amazing amount of info about this is available at silentpcreview.com
PC Tower Case - Quiet for In-Room Audio? lowlights Windows 3 09-04-2012 07:08 PM
PT10 USERS for advice on best NON-SSD Drive, 6 core vs 4; Quiet/Cool Case? reeltape Windows 5 04-11-2012 12:10 PM
ot Need Advice About Room EQ DHG MUSIC Pro Tools TDM Systems (Mac) 11 07-25-2010 09:33 PM
Drum recording: 3 room choices, 3 channels, 4 mic choices - pls lend your advice!! edgarbc1 Tips & Tricks 4 12-03-2009 08:40 AM
Advice on building out room for recording acoustic guitar Son of David 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-07-2002 08:15 AM
