Activity Monitor
Hi.
I've recently started to put this app in the dock to see what's going on. I did this because RAM usage has increased considerably since I bought DFHS and C&V from Toontrack. On one session I didn't have any more free RAM, and re-activating an instrument track with Ivory inserted forced an unexpected quit. Do I really need more RAM? Thanks.
Re: Activity Monitor
Activity monitor is not the app you need to check your RAM usage. Try Memory Stick. It will show you when a new swap file is created and wired, active, innactive, free RAM. Very simple to use.
Memory stick There is one version for each version of Mac OS X. JC |
I've been using activity monitor for the same reason! As far as i'm aware 4 gig is the max any one program can use!! but having 5-6 gig is probably the ultimate to allow for background apps etc. Never quite sure how programs like Live/reason/melodyne are brought into the equasion!? are they part of PT 4 gig usage or are they considered a seperate appplication. Chris
I actually took a screenshot a bit earlier in the session, where I had Activity Monitor open also.
These are the numbers (System Memory): Wired - 425 MB Active - 467 MB Inactive - 3 GB Used - 3.9 GB Free - 650 MB VM size - 7.8 GB Page ins/outs - 59128/215 Later in the session I noticed that I didn't have any free RAM and thus started thinking that's why PT had an unexpected quit. Anyone that can verify these numbers as "normal"? Thanks for your time.
Why does PT8 not show up as a 64 bit process in the activity monitor? | jj5000 | Pro Tools M-Powered (Mac) | 2 | 02-27-2010 10:06 PM |
Alternative to activity monitor | suicune | Pro Tools TDM Systems (Mac) | 2 | 10-05-2009 05:14 AM |
MBox2CS in the Activity Monitor | stainless | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-01-2009 08:13 PM |
Pegged HD Engine on Activity Monitor | palmer_jankens | Pro Tools TDM Systems (Mac) | 2 | 12-01-2008 04:08 PM |
How can u monitor PCI bus activity? | legativity | Pro Tools TDM Systems (Mac) | 1 | 07-13-2001 02:46 PM |
