Old 10-13-2002, 01:26 PM
Steve Rieck Steve Rieck is offline
Default Studio Vision Pro - Audio works great on OS9 now ! really
For anyone who misses SVP,
All you need are the NEW OS9 updated Acadia files available here:
http://www.fm-music.com/v/setup/setup.html
Also, these new acadia files seem to only work with the most recent SVP 4.5.1 upgrade available here:
http://www.opcode.com
I happen to be using a 001 with direct i/o
-No more file read errors
-No weirdness
-Seems very stable
-Full automation including effect parameters
Old 10-14-2002, 12:34 AM
Larryboy Larryboy is offline
Default Re: Studio Vision Pro - Audio works great on OS9 now ! really
I still have nightmares about using that version with OS 8 and how I felt the $25 upgrade was a big waste. I went back to 4.2. Exactly which OS are you using?
27in 3gHz Intel iMac w/8gb RAM, 13" MacBook Pro 2.7gHz i7, Pro Tools 10, Logic Pro 9, Apogee Quartet, Grace M101, Rosetta 800, Speck X-Sum, Roland XV-5050, Event PS6
Old 10-14-2002, 06:18 AM
OS9.1
Be sure to get the freeware upgrade (at www.opcode.com) along with the new OS9 acadias.
Old 10-14-2002, 09:22 AM
naireko naireko is offline
I can use my digi001 via asio but not via DAE. DAE crashed except when I use it through the asio direct i/o driver. It is my understanding that this acadia thing is kinda like an asio bridge or something. Are you actually using DAE in the setup menu or acadia/asio? Your right though it does work as long as I have the digi001 asio driver installed in the asio directory. Thanks.. Thanks. here's the links that i found to the digi001 asio driver that is required... what happened to where it used to be? I can't even find the digi link to it.
http://www.audibleresponse.com/ASIO_...n_DirectIO.sit
Or...
http://service.steinberg.net/downloa...bd057c12568e40 031e32b/$FILE/ATTGQLXX/ASIO_DigiDesign_DirectIO.sit
Old 10-14-2002, 10:59 AM
No DAE, I'm using the direct i/o driver that comes with the digi001 when you install PTLE software.
Old 10-14-2002, 11:30 AM
So this is through ASIO then? what i mean to ask is.. do you have the digi001 asio driver installed in the asio folder in the root of your StudioVision pro directory?
Cause if there's any other way i would like to check it out as the asio driver has a 32 ms of latency not that i monitor through the tape heads anyway but the asio performance has always sucked,crashed and cause me all kinds of headaches. under cubase anyways.
Old 10-14-2002, 07:03 PM
There is a direct i/o driver in my asio folder.
I also have the digi direct i/o extension installed.
In visions "hardware setup" window I select "direct i/o"
Old 10-14-2002, 07:45 PM
The direct i/o driver in my asio folder is not the same as the one you mention and have a link to above.
I think that one is made by steinberg and the one I have is made by opcode.
Old 10-14-2002, 08:39 PM
interesting. I'll look more into it. Can you email me the direct i/o driver so i can work with it, compare it to the digi001 asio driver and post it on my web site?
send it to ckerian@crystalclearrecording.com
Old 10-14-2002, 09:01 PM
done.
It will be interesting to check out if one outperforms the other, I'll try both also.
Whoopi! Studio Vision Pro works on 9.2.2 & 001 aka21stCentury 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 10-11-2014 03:06 PM
Anyone still using Opcode Vision or Studio Vision? Boom Chic MIDI 1 05-22-2002 12:35 AM
PT 5.0 with Studio Vision Pro Altrack Pro Tools TDM Systems (Mac) 1 06-23-2000 10:55 AM
OMS Studio Vision - WHAT DO WE DO NOW? 2 bit Pro Tools TDM Systems (Mac) 1 10-10-1999 12:12 AM
Studio Vision Pro Antonio Fernandez General Discussion 5 08-14-1999 11:28 AM
