Edit/Mix window bank to selected layout?
Curious if anyone knows a way to bank the edit/mix window to the faders of a selected EUCON layout? Currently my workflow is to select the layout on the Dock and then ctrl-shift select the first track on my S3 to scroll the faders into view in the edit window. It'd be great if all I had to do was select the layout for that to happen.
FYI, I have Edit and Mix windows follow bank selection selected in my prefs. Thx! J.R.
J.R. Fountain credits: www.imdb.com/name/nm0288354/ system: Mac Studio Ultra, 128 GB RAM, macOS 13.6.1, MTRX Studio, S3 / Dock, PT Ultimate 2023.12 |
Re: Edit/Mix window bank to selected layout?
It's bad to assume your layout is even in the same order that it'd show up on your edit or mix window. I think this is why it's not a function.
-Ryan Young •2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Ryan is right. Most people use layouts to "cherry pick" tracks from all over a sessions. Banking would be impossible.
Perhaps you should be looking at VCA spill instead? |
Good point Ryan, I hadn't considered that since I'm not using them that way. I just see the highlights around my tracks the same way as I would if I were to bank them and assumed that the edit/mix window would follow.
Lynn, I do use VCA's as well but liked layouts better because they retained the track colours and I liked instantly selecting them from the Dock instead of spilling/unspilling/spilling to change groups. Thx!
Thanks Lynn, I'll check that preference. I've always spilled the VCA's from the S3 by double clicking the select button.
The track colours might be an S3 thing, whenever I unspill a VCA it turns them green, I'm assuming to indicate that you have a VCA spilt.
Ah, youre right. The little chicklets turn green during a spill. Us S1 people have the advantage of the color meter display. The things you dont notice til you look. |
Edit/mix window follows bank selection | brandonc23 | Pro Tools 12 | 0 | 02-20-2016 10:59 AM |
Edit window jumps to track when using layout | Eruk | Avid S1, S3, Dock and Control App | 0 | 10-30-2015 05:22 AM |
Edit/Mix Window Follows Bank Selection | maxtn | Avid S1, S3, Dock and Control App | 14 | 04-06-2015 05:30 PM |
edit/mix window follows bank selection Eucon/PT9? | engininja | Artist Series | 47 | 11-23-2014 09:42 PM |
Edit Window Follows Bank Selection. Edit Window Follows Bank Selection. Edit Window.. | Focuret | Artist Series | 17 | 01-18-2014 03:53 AM |
