Re: can't record
Oh that should be fine. I have a drive I've been beating on for like 8 years but you never know..
Re: can't record
No problem leaving a drive spinning all day. They're made to do that. Your computer's internal drive spins all day. |
Re: can't record
I am getting the same message with PT10 and an mbox 3. The system drive is brand new and set to read and write as is my external G Drive (which is new also). I've tried sessions on both drives, nothing, same error. Disk allocation is fine. Did anyone find out what's up. I have a session in the morning.
Thanks J |
Re: can't record
James,
I don't really know what the problem was for me. I checked the drives. Trashed preferences. Tried to verify the disk in disk utility. It wouldn't unmount. Repaired disk. Nothing seemed to make a difference. I decided to be done for the day, and try again the next. The next day, everything was fine ( it took a while for my external drive to show up on the desktop ), and everything has worked fine since. Go figure. Hope your's is fine as well. |
Re: can't record
Hey,
Since this worked for a couple years and now seems to have some bugs, have you done a repair disk permissions on the G-Drive? Just open disk manager and select the G-Drive and hit Repair permissions.
-Systems Engineer, Systems and Sound Designer, Recording and Mixing Engineer |
Re: can't record
Disk permissions repair doesn't work on external drives - only the boot drive. You can verify an external drive but that's a different animal than disk permissions.
Re: can't record
I think I may have confused checking for errors with disk permissions.... you should have this as an option on an external drive.
I was referring to this:
Re: can't record
The op won't have that as what you're showing is for a Windows machine and we're talking about a Mac here.
Re: can't record
I am on my windows partition and cant swap due to my job, but you can do the same on a MAC just go to Disk Utility under accesories... or rather Utilities
https://tuts-authors.s3.amazonaws.co...kutility-1.jpg
Re: can't record
On my MAC side now and looked into this....
On my external drive I have the option to "repair disk" as shown in the picture.... This is what I was referring to but had to be on Windows yesterday.. see image.... see bottom right option that says REPAIR DISK.
Session must be on an audio record volume if permmited set the volumes to R record | lionandthemouse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-11-2013 01:48 PM |
Record 1 audio track, then go to record a second, the timer button flashes... help | tdubthatsme | General Discussion | 5 | 02-27-2011 04:39 PM |
MIDI record enabled and found but wont record | BCRich | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-23-2010 12:51 PM |
Press Arm Record then Play and have to wait 3 miniutes before record/playback starts | The Muphin Man | Pro Tools SE and Essential (Win) | 8 | 09-10-2010 07:03 PM |
Crackling in record mode (even when not actually recording), cannot record > 10 secs | chandra | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 08-16-2010 09:08 PM |
