Old 08-06-2010, 12:55 PM
matchoo0 matchoo0 is offline
Default Sync HD, Loop Sync, Max BNC Length?
Hey There,
I'm plotting out a wacky HD configuration that is going to have my Synch HD and 192s set up far away from each other. I think I have it figured out, but there is one question that I couldn't find an answer to. My question is regarding the BNC cables used for loop sync between interfaces. Is there a maximum cable length? If I'm using 75' (23 meters) of cable to loop synch my interfaces am I asking for trouble?
Best,
Matt
Old 08-06-2010, 01:39 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Sync HD, Loop Sync, Max BNC Length?
Originally Posted by matchoo0 View Post
Hey There,
Best,
Matt
Would have to be good quality cable for that length! but should work ok.
Chris
Producer, Engineer,
www.ukmastering.com
Old 08-07-2010, 01:31 AM
johnsimmons johnsimmons is offline
i had a problem with a particular 10 metre cable, but not with another so i'll echo and say quality is important.
Sync I/O and a single 192 I/O Loop Sync or not? Zapakos Pro Tools TDM Systems (Win) 8 06-12-2016 08:41 PM
Sync HD with Aurora 16 w/o Loop Sync even possible? PleaseDontCrash Pro Tools TDM Systems (Mac) 2 09-26-2008 08:02 AM
SYNC I/O Macintosh serial cable - max. length????? Andi R Pro Tools TDM Systems (Mac) 9 02-27-2007 11:10 AM
SYNC I/O and Loop Sync Chief Technician Post - Surround - Video 2 06-21-2006 06:28 PM
HD, Sync I/O, loop sync and clocking Will Russell Pro Tools TDM Systems (Mac) 7 04-09-2004 01:38 PM
