Old 01-17-2007, 01:39 PM
GTBannah GTBannah is offline
Default Re: computer in other room...long cords?
I found a 25' extension cable (monitor, keyboard, mouse) for $34. Do you guys see any inherent problems with this?
http://www.action-electronics.com/switchboxes.htm
I would hope/assume that they would test it before they put it on the market ....
Derrkins
GuyBarTola
PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!!
Old 01-17-2007, 01:48 PM
JMS40 JMS40 is offline
I used a 50 foot VGA extention in an AV setup a few years back.
There was a very slight "ghosting"... nothing that would remotely get in the way of use with PT or even average PC usage.
I wouldn't recommend it for a graphics editing suite, though.
Old 01-17-2007, 10:01 PM
guy.fi guy.fi is offline
Thanks guys. I'm going to try it, I'll let you know how it goes.
Asus P5K Deluxe
Pentium Q9550 @ 3.4 ghz
Corsair 1066 RAM
www.guyfi.com
www.flystudiosmilwaukee.com
Old 01-18-2007, 10:01 PM
outoftune outoftune is offline
Default Re: computer in other room...how long can cords be
you should check out silentpcreview.com
trying to make your pc quieter would save you the hassle and the added problems of running extension cables. simple stuff like swapping out fans will make a huge difference.
Old 05-30-2007, 07:36 PM
Well, I've been using these long cables for a while now with no change in performance. My control room is silent!
Asus P5K Deluxe
Corsair 1066 RAM
www.guyfi.com
Old 05-31-2007, 09:53 AM
SixChurchStreet SixChurchStreet is offline
I use very long VGA cabling for Audio Visual installations, and it's usually fine, as long as it's good quality large gauge cable. If needed you can use a booster in between to amplify the signal a little more if you're experiencing ghosting. I've easily run 100'+ without a problem.
Mac Pro 5,1 2.4GHz 8-Core 16GB RAM High Sierra | Focusrite Scarlett 6i6 Mk2 | Pro Tools 2020 | Studio One 4
Like to move computer & drives to next room - cable length? arthur s 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-13-2007 06:31 AM
How far is your computer from your control room? wiota Pro Tools TDM Systems (Win) 4 07-24-2005 07:50 AM
How can I put the computer and hard drives in a machine room. rodrigal Pro Tools TDM Systems (Mac) 6 08-27-2001 03:46 AM
can I leave my computer on 4 long periods? tross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-09-2001 05:25 AM
Planning machine room for noisey computer / bit 3, advice please Tips & Tricks 16 07-16-2000 03:12 PM
