Old 11-14-2022, 04:03 AM
marmouch273 marmouch273 is offline
Default Soft keys issues pt 2022 10.0
Hi there
Cannot make customs fader with plugin parameters on them with a S6. The «*attention button + exp button » doesn’t work anymore ?
Did I miss something (a setting to enable for ex ?)
Also, I’ve experienced some soft keys issues. Can’t make a «*key*» command soft key (like shift+cmd c / shift cmd v for ex)
Thx by advance
Cheers
Old 11-14-2022, 06:19 AM
creativecontrol's Avatar
Default Re: Soft keys issues pt 2022 10.0
Greetings,
As of EUCON 21.6 with Custom Maps, the whole flow of customizing Fader Maps and also Knob Maps changed.
I would recommend consulting the docs for more detailed instructions but here's the basic gist:
Attention a track containing the Plug-In Insert you want to map. From the Master Module, touch to select Inserts then press an encoder associated with the desired plug-in to push in and show the parameters. Touch Custom in the bottom left hand corner of the Master Module. Now, for mapping to Faders -> touch the fader module lit in purple to select that map type. Touch the Master Module Screen to select a parameter then touch a Fader to associate and correlate that parameter to that strip location. When finished, press done.
https://avid.secure.force.com/pkb/ar...Product-Guides
Jeff
Jeff Komar
Solutions Specialist, Pro Audio
S6 FAQ
Old 11-14-2022, 09:25 AM
Hi Jeff
Wow thx for the quick answer :)
Gonna check that right away And re-do my homework
Have a nice day
Regards.
S1 Soft Keys Tone_Mechanic Avid S1, S3, Dock and Control App 1 01-20-2021 03:11 AM
Soft Keys - System Soft Key Display Mode skilletaudio Avid S4/S6 0 09-25-2019 10:07 AM
Soft Keys walter rohrbach Avid S1, S3, Dock and Control App 2 05-11-2019 01:26 AM
How to Adress Function Keys >F12 from the S6 (Soft Keys) innenhofstudios Avid S4/S6 3 05-08-2019 07:34 AM
Why no Soft Keys on S3? jacko Avid S1, S3, Dock and Control App 15 02-09-2016 08:43 PM
