Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 02-10-2021, 09:39 AM
lavastudios lavastudios is offline
Default Recovering RTAS plugin settings from old session
Hey gang,
So I've got to go back to some mixes that were done on PT10 with RTAS plugins. Does anyone know if there's a way I can recover the settings for the missing RTAS plugins so that I can open them in AU/VST form via Blue Cat PatchWork or a similar wrapper tool? In the past I have done this by opening PT10 and saving all the plugin settings as custom presets, then opening those presets in AU/VST versions of those plugins via Blue Cat PatchWork, but I no longer have a machine with a PT10 install. Is there another way?
Thanks!
Simon
Old 02-11-2021, 04:49 AM
Default Re: Recovering RTAS plugin settings from old session
Originally Posted by lavastudios View Post
Hey gang,
Thanks!
Simon
Not that I know of.
Why do you have two threads on the same subject? Not cool and against the TOS. Maybe one of the mods can delete the duplicate thread.
Jack
QAPLA!
Old 02-11-2021, 06:04 AM
Originally Posted by musicman691 View Post
Not that I know of.
I'm not sure what happened there. Clearly not intentional though - I posted once and it didn't show up at all. I hit the back button and the text I'd written was still there but it wouldn't let me submit the post, said I already did. I copied the text so I wouldn't lose it then waited a couple of hours and it still wasn't showing up as a thread, so I just created a new thread. I couldn't see a duplicate at the time, but now I can
Old 08-15-2022, 05:07 PM
milet22 milet22 is offline
Simon, did you ever find a workaround? I'm experiencing the same situation / need.
Old 08-15-2022, 07:22 PM
Who are you talking to?
Jack
QAPLA!
Old 08-17-2022, 01:06 PM
Back to the original issue, I see only 2 options:
1-find someone with an older setup, open the sessions and take notes or screen shots of the settings you need.
2-don't be afraid to just start over with a different but similar plugin.
Some plugins did not make the transition intact(why those plugins won't come up on newer systems). If you consider how often before DAW's, when engineers had to resurrect a complete mix with next to nothing to go on, we are still miles ahead on recalling a mix. Personally, the few times this issue hit here(and it has), I simply take it as a challenge to better the old mix(and I usually do). That might happen due to newer and better plugin options, or it might be down to fresh ears
If you mention the plugins you are wishing for, I bet the folks here will have some good suggestions for substitutes
Plugin settings disappear when reopening the session - PT 10.2 Luke83 macOS 0 07-27-2012 08:06 AM
Saving session plugin settings David P. Green 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-24-2006 06:03 AM
Importing a whole session's plugin settings vetsen Tips & Tricks 2 02-14-2004 11:11 AM
Is there a website that contains plugin settings for various RTAS/TDM plugins? Fucius General Discussion 2 06-07-2001 02:43 AM
