Old 06-05-2014, 11:19 PM
Analog Kid Analog Kid is offline
Default Failed Installation; Help!
I have purchased a second-hand copy of Pro Tools 9; it's an upgrade for me as I have been (and still am) using LE 7.4.
I have attempted to install Pro Tools 9 from the cd several times; all attempts have not worked. Whenever I attempt to install it, the progress bar will show 3-4 minutes left before completion, and than it will suddenly stop with the error, "The installation failed; there were errors with the installation. You may want to try installing again". What gives?
I have partitioned my hard drive to be a dual boot system. One partition boots from Leopard (and that partition has LE 7.4 installed), the other partition boots from Snow Leopard (and that is where I am attempting to install Pro Tools 9).
I have an Mbox 2, and I have updated the drivers (version 10.3.3, I think).
One other thing that I have noticed is that when I start the installation, a dialog box indicating that some keyboard shortcuts need to be disabled in the Apple System Preferences appears. I have disabled all the keyboard shortcuts that the manual indicates to disable.
The system specifications are:
mid 2007 Aluminum iMac
Intel Core 2 Duo Processor, 2.0GHz
4 Gigs Ram
OSX 10.6.8.
Can anyone help? Please?
The Kid
edit: I do have an iLok with the appropriate licenses on it.
Old 06-06-2014, 11:25 AM
Default Re: Failed Installation; Help!
Update: I was able to able to do a successful installation. However, I did nothing differently than before; perhaps 5th time's a charm?
The only possible guess I could have, and it's strictly a guess, is that when I had tried before the computer had been on all day and was warm to the touch. When I tried the very last time I had just turned it on after it being shut down for a period of time. Perhaps something in the optical drive warped ever so slightly due to heat; just enough to not track correctly, causing errors during installation? That's just a (far-fetched) guess; I'm not a computer technician by any stretch of the imagination.
Anyhoo, it works.
The Kid
Old 06-06-2014, 08:00 PM
Glad you got it sorted. You know, its not that tough to swap out the optical drive for a second internal hard drive, and you can always add a USB or FW external optical drive
Old 06-08-2014, 10:07 AM
Thanks. I have actually started to second guess my, "theory", as other dvd's seem to work just fine. Soo suspecting perhaps the dvd itself, just to see what happened, I decided to copy the installer to a usb drive. Sure enough, it got about halfway through copying to the drive and then encountered a bunch of errors.
I guess I will need to purchase a set of replacement discs if I ever need to reinstall PT.
The Kid
Old 06-09-2014, 08:18 PM
If you are the registered owner of PT9, then you should be able to log onto your "MyAvid" account and download the software
Old 06-16-2014, 12:54 AM
Just saw your reply; I will check out my account. Thanx!
The Kid
[IMG] code is Off
Eucon installation failed Uganda Artist Series 0 05-15-2012 11:42 PM
PT 8 Install DVD: Installation Failed bender-offender 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-24-2011 06:19 PM
Installation failed!! dkean Artist Series 1 12-24-2010 06:00 PM
Pro Tools 7.4.2 on Mac OS X 10.5.6: Installation failed crustn Pro Tools M-Powered (Mac) 8 05-08-2009 03:45 AM
Installation Failed Tamlin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-04-2009 02:18 PM
