Hi
I just bought RC-Tube from Slate Digital with new iLok2 included and have some strange issue with new iLok2..Sometimes in the middle of session it stops my work and says that there is no PT10 HD licens on my iLok2 nad crashes PT.. Afterwards I have to put iLok2 in to onother usb port ..and sometimes I'm able to start PT again and sometimes not.. What's this time ?!?!? Greetings, jacek
Musician,Producer etc.. PT|HD Ultimate Native , UAD-2 Octo x2 , Win 10 Pro 64 bit, AMD ThreadRipper 3960X (24 cores 3,7Ghz (48 threads), 64 GB G.Tech DDR4 3200MHZ ,Gigabyte TRX40 Designare (with Thunderbolt), (Philips 40'LED screan) , Samsung 24" LED 2x192 I/O, Nuendo 4.3, Wavelab 6, Halion 3.5, Yamaha 02R96V2, AvalonAD2022, AvalonVt737sp etc... www.MrPollack.pl ,www.facebook.com/polak.bros.studio |
![]() Quote:
Sounds like that could be either of the following : - issue with the ilok drivers : Can you uninstall and reinstall the ilok drivers with the latest from pace : http://www.paceap.com/dldrvr.html - issue with your USB ports. Are you using any other USB devices that may draw too much power from your USB ports ? Eliminate those devices and see if you can narrow it down like that - issue with the physical ilok 2 in which case you will need to contact Slate Digital or ilok.com and raise a case with them Chris
Chris Lambrechts Applications Specialist- Live Sound |
I've just had a similar issue on PT10HD running on Lion (10.7.2). I resolved it by reinstalling the ilok/pace drivers. Definitely a bug of some sort. It was regarding Slate's Trigger and the built-in TCE plugin! Odd....
This happens to me with RC Tube/VCC/PT 10 on iLok 2 also, but it's when I disable my network connection. I get the same warning, but if I simply re-enable the connection all is well. Very annoying.
Win7 |
Try moving the slate digital license over the Ilok that holds your pt 10 license. Might solve your problem. You need to go to Ilok.com and log in to your account to do that.
they're both on the same ilok (ilok2) and the slate digital requires an ilok2
Have you tweaked all USB ports to turn OFF the power management function?
Gigabyte X79/intel i7 3930K, 32GB RAM, HD/Native, 192 IO https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
I think Ant B may be right.... During my sessions I usually disable my internet connection/network ..I'll check it out today and see..and I'll try to reinstal ilok drivers too..
Thanks guys for you advices ![]() jacek
I have had VCC for many months and RC-Tube since the day it was released. I have never had an Internet connection active. I have had this issue with older ilok drivers such as the one installed with some the PT installers, but after updating them with the latest from the Pace website all issues were resolved.
~ tom thomas Formerly hobotom Pro Tools Ultimate 2022 HDX HD Omni and 192 I/Os Windows 10 Intel Hexcore i7 All Samsung Pro SSDs Ampex MM1200 2" 24 trk tape Outboard: UREI, Eventide, Lexicon, Yamaha, TC Electronics, Orban, ART, EchoAudio, Dolby, Hughes, API, Neve, Audio Arts, BBE, Aphex, Berringer, MOTU, dbx, Allison, etc. Plug-ins: Too many to talk about. www.metrostudios.com |
It's a long shot but on my system (with both PT9 and PT10) I have conflicts with my Bluetooth adapter hanging off one of my USB ports. Sometimes PT works fine with the Bluetooth adapter plugged in, but other times PT can't find the ILOK2 Pro Tools licenes. If I unplug the adapter, PT then finds the ILOK2. Oddly "turning off" the Bluetooth adapter in software doesn't work. Also my ILOK1 works fine with PT with the Bluetooth adapter left in. Seems the ILOK2 is more finicky about the system.
iLok1 to Ilok2 transfer PT10 can't see license | New Hope Media | macOS | 3 | 01-02-2014 06:09 PM |
iLok2 for Pro Tools 10? Why?? | Lehrman | Pro Tools 10 | 12 | 06-19-2013 09:47 PM |
ilok2 issue | abre | Pro Tools 10 | 12 | 10-07-2012 08:10 AM |
Fresh PT10 install ilok2 drive names too long | Blissful World | Windows | 3 | 02-08-2012 11:57 AM |
Slate VCC and ilok2 | MikeLip | Windows | 30 | 04-01-2011 10:04 AM |
