I have Pro Tools 9.05 with Axiom 61 (1st Gen). Win7 Pro64.
To select next track on keyboard, I click Start+p or Start+; Is there a way to do the same using Axiom 61 keyboard? Can I program Axiom 61 so I can select the next tracks in Pro tools ? Thanks
http://about.me/jeanpaulzoghbi Pro Tools 9 HP Z600 Worstation- Dual Processor Xeon E5620, 2.4 Mhz, 8-core, 24 GB Ram, Nvidea Quadro 2000 1 GB Graphics card. |
Jeanpaul, does Axiom Gen.1 support ASCII Keystrokes?
Aaron Mulqueen - 001 HD Native |
Thanks filosofem for your reply.
I dont think ASCII is supported in Axiom 61 ![]() I would like to be able to select the next midi track while I am in VE PRO window, and not have to go to Pro Tools window everytime. So the Axiom midi controller is what I hoped would do the trick. However, just in case it is supported, how do you assign the keystroke to Axiom61? And in the most likely case that it is not supported, is there any way to convert the keyboard shortcut into a midi message? thanks
Your latter question I could not answer but the former I was thinking assigning keystrokes from Axiom Keypad but such functionality is not supported. However quickly reading through Axiom Guide, Axiom does support a number a programmable possibilities. Perhaps VEP can conform. There is often more then one way to skin a cat.
![]() Quote:
In principle, I need to write the script in Autohotkey and execute it via MT when midi is intiated on the Axiom 61. I am still experimenting but will post the results if/when I succeed thanks JP
Great work JP.
MC Transport - Jog Track Select | PlugSlut | Artist Series | 7 | 03-29-2012 06:56 AM |
Axiom Pro 61 Patch Select | Speeder | Virtual Instruments | 2 | 09-06-2009 09:38 AM |
"select next/previous track" "rec enable track" key command? | maufau | Pro Tools TDM Systems (Mac) | 6 | 04-22-2008 06:08 PM |
Is there a way to link track select and track focus? | uno1234 | ICON & C|24 | 13 | 02-14-2008 03:36 PM |
PT 6.9 track select bug | trakbytes | Pro Tools TDM Systems (Mac) | 3 | 04-20-2005 04:20 PM |
