Old 03-17-2010, 08:16 PM
xxicjoy xxicjoy is offline
Default Loop playback Problem
Ok New to o8.0.3 so maybe this is old hat. in loop playback, If a section is selected it only plays from the beginning of the selection if Link timeline and edit selection is checked, however it deselects the previously selected area when I hit stop. How do I get it to play from the selected startpoint and maintain the selection after stopping?
Hmm just double checked, is working correctly in a new session. Is this a bug??
Old 03-17-2010, 08:42 PM
Craig F Craig F is offline
Default Re: Loop playback Problem
Most likely Insertion Follows Playback pref is unchecked (the N key is the toggle, often bumped when hitting the Space Bar)
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 04-12-2011, 04:48 PM
Java Java is offline
This has been driving me nuts. Finally an answer. When did they add this feature? When they implemented Keyboard Focus? (Upgraded from version 6 here and I am hurthing!)
Java
Old 04-12-2011, 05:49 PM
v4 I think, been there as long as I can remember
Thank you,
Craig
Old 04-12-2011, 09:27 PM
WernerF WernerF is offline
Been there as long as I can remember as well.
Old 04-14-2011, 04:33 AM
Yes but was "Keyboard Focus"? There is also the shortcut "Control+N". It's so easy to mistakenly hit that as well.
At least the garbage has been removed from the brain now so I can start plowing ahead. Frustrating though to have the creative process flowing so nicely and then *SLAM* ... Brick Wall, Do Not Pass "GO", Do Not Collect $200.00.
Thanks comrades.
J.
Java
Problem PT11 MAC stuck in "Playback Engine" selection reload loop fastermaster Pro Tools 11 3 06-28-2013 05:28 PM
weird Loop Playback/Groove Problem perfectdrug6 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-20-2011 10:39 PM
Loop Record and Loop Playback will not engage? Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-28-2008 07:03 PM
Need Help With Loop Playback/Cursor Problem djcream 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-21-2007 06:11 PM
