I would like to save some 5.1 backgrounds I made to Soundminer and be able to drop them back into Pro Tools for use. I tried exporting them as "stereo" files, thinking they would be 5.1 interleaved. But when I drop them back into Pro Tools from S.M., I only get 3 mono tracks in the region list.
Any ideas? Mike
Michael McDonough, M.P.S.E. Michael McDonough Sound Design |
Okay, I think I figured it out! Instead of using the "S" command, I used the "send to" arrow icon at the top of the window, and it sent it down the transfer path to the region list in Pro Tools as a 5.1 interleaved file. It comes in as LCR,LsRs,Sub instead of the SMPTE format, but I can deal with that!
Hope this helps someone else. :) Mike
Hi, yes it comes in as LCRLsRsLfe - if somebody knows why - please explain it to me:) I've tried to change that, but it seems unconfigurable? :)
Impossible to see the future is. MBP 2.5 /4GB RAM, Mbox2 Mini, PT 9, OS 10.6.8 |
![]() Quote:
PT only supports this format. I wish it would import SMPTE BWAVs but it doesn´t. frank.
PTHDn 2022.12 (OSX12.6.2), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM, Xilica Neutrino, Meyersound Acheron |
![]() Quote:
PT does not support interleaved files. You have to set SoundMiner to split-mono in the transfer prefs. frank.
Also be careful that no VST plugs are in the chain. Most (if not all) will create a stereo stream in PT despite your surround source files. When I have interleaved multichannel stuff that I want to xfer (more than two channels) I still perform the "reveal in finder" command, and drag and drop manually. But, that's just me.
IMDB |
![]() Quote:
Mike
I seem to recall the previous version (3) of Soundminer would let you choose the sort order, film, smpte, DTS .
I noticed they didn't put that into V4. Are you using V4Pro? Definitely a feature request for the Soundminer folks. A personal thanks to you Mr. McDonough. I can't tell you how many times I've used your sfx(6039) for my productions over the years. It must be great to hear your stuff being used thousands of times a day. Cheers |
PT is all about the "Film" 5.1 track order while Media Composer is default to output in SMTPE/ITU. I can't help but find that funny. :)
My problem is trying to "Spot To DAW" with non-interleaved individual 5.1 tracks from a production elements library. It will only spot the L track. I have to "Reveal Selected" in SoundMiner and group drag the individual tracks to 6 mono tracks (to make sure the track order is Film) and then drag those to a 5.1 track. Not as convenient as spotting really. |
Yeah, let's hope Digi/Avid gets the SMPTE order going for Pro Tools at last one of these days...
My 5.1 outputs are SMPTE order, so LR are mapped the same and there's no repatching or rerouting to work in stereo. It just makes sense. (to me, anyway.) As for Soundminer, the surround track order of files stored in the database can be stored on a per-sound basis, in the "ChannelLayout" field. Look at the SM documentation for the format, or write Steve if you can't find it. It's important to put the right format in that field, or else your files might be delivered into Pro Tools with the wrong assignments. -jeremiah |
Soundminer or?? | soundboy35 | Pro Tools TDM Systems (Mac) | 4 | 03-27-2015 08:24 AM |
Do I need Soundminer? | Mitch Griffin | Post - Surround - Video | 10 | 04-04-2012 10:52 PM |
Soundminer importing only partial files | amiller | Post - Surround - Video | 8 | 02-28-2011 06:05 PM |
Soundminer and Cantar files | Studio Studio | Pro Tools TDM Systems (Mac) | 0 | 09-11-2006 04:27 PM |
