Here's what I got;
G4 867 running 9.2.1 with 640 Meg RAM 13 slot Digi (Magma) expansion chassis ProTools AV (AVBV board set) 5.1.1 2-18 Gig Seagate Cheetahs in fast and wide Glyph enclosures ATTO card running 2.7 EPT Nvidia AGP card (single) 2 Sony 15" LCD monitors (one connected to the Nvidia, the other to the ABVB) Machine Control v 1.0.1 USD with most recent USD setup House sync feeding USD and sync input on ABVB Here's what's happening: I create a new session on my drive called AUDIO. I can create new audio tracks no problem. I create a movie track. With machine control I try to pull in audio and video from a digibeta. The audio seems to record fine, but the video is about 10 frames long and starts just before my record in point. If I try to play, I get "A Program Error Has Occured" After that, every other attempt to play brings up the error. It has also affected the whole system so badly that I have had to reinstall ProTools about 6 times today. I've reseated every card, I've reinstalled every program, I've tried recording audio on my VIDEO drive and video on my AUDIO drive. All to no avail. I've run Digi test and the Avid system tests, everything seems to check out. What have I missed? [img]images/icons/confused.gif[/img] Thanks in advance for your input.
Ninja Bob Hothead NYC |
You need LTC from the Beta to the USD or be using Serial Timecode. And assign GOBS of ram to everything. I have a similar setup, and it runs great. Good Luck.
[img]images/icons/smile.gif[/img]
Ray Trujillo Freelance Audio Engineer |
Thanks for the reply Ray, but nope, that's not it. I do get time code via serial, and the machine locks to the ProTools no problem.
Does Digi have any insight on this? Thanks.
Update on the sitch.
Turned out it was a bad ABVB card. Next day turnaround with the advanced replacement was a BIG help. Thanks Jordan!
"pro tools hardware is not installed or is in use by another program error" | beatingunicely | Pro Tools 11 | 0 | 01-17-2014 09:14 AM |
PT9 Session Troubles - "Bus Error" in "Main Thread" & Could not complete the Open... | tohmit | macOS | 5 | 03-23-2011 01:13 PM |
iMac PT LE 7.3cs1 Rack 003 Error "Not Installed or Used by Another program" | gcharles | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 12-01-2010 09:24 PM |
Pro-Tools Error "in use by another program" | j_north | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-18-2010 11:15 PM |
"Program error" with AV:XL and PT5.1U | Mario C | Post - Surround - Video | 5 | 09-19-2001 12:10 AM |
