Issue with Melodyne Studio 5 after updating from 4
PT 2022.10
Win 10 pro. Recently updated from Melodyne Studio 4, to Studio 5. In PT prefs menue it says "Celemony ARA". But I see it studio 5 listed as "Melodyne" under "Other" in the plugin's menu... is this right? Problem is that I STILL also see Melodyne 4 listed under "Instruments? If I try to load it, a message appears that says ..."AAE Error code 20038 was encountered"? I was told by Celemony tech support to Un-install 5 and re-download it, then re-launch. Did that and still seeing what I described. Anyone else having similar problems? Thanks. Last edited by ihate100bees; 11-29-2022 at 06:39 PM. Reason: scenario changed |
Re: Issue with Melodyne Studio 5 after updating from 4
Ok... FIXED the problem by trashing PT Preferences, than going into Windows App folder, and locating the hidden Melodyne Un-install aplication. Re-installed Melodyne Studio 5 and everything looks good... and no visual of the old Studio 4. Hope this helps someone else.
Why are MIDI notes 1-2 samples ahead? 2022.9/2022.10 | gthm | Pro Tools | 9 | 06-30-2023 01:10 PM |
Melodyne doesn't render properly after TCE Tool 2022.10 and 2022.9 | Dizzi45Z | Pro Tools | 4 | 01-04-2023 02:31 PM |
Super SLOW mp3 import bug is back in 2022.9 and 2022.10 | akproductions1 | Pro Tools | 12 | 11-01-2022 08:48 PM |
Will sessions created in 2022.9 open in 2022.7 | michael c | Pro Tools | 1 | 10-21-2022 09:09 AM |
Crash moving tracks to new Routing Folder in PT 2022.4 [FIXED 2022.5] | Dizzi45Z | Pro Tools | 43 | 05-29-2022 03:59 AM |
