Hey gang,
So I've got to go back to some mixes that were done on PT10 with RTAS plugins. Does anyone know if there's a way I can recover the settings for the missing RTAS plugins so that I can open them in AU/VST form via Blue Cat PatchWork or a similar wrapper tool? In the past I have done this by opening PT10 and saving all the plugin settings as custom presets, then opening those presets in AU/VST versions of those plugins via Blue Cat PatchWork, but I no longer have a machine with a PT10 install. Is there another way? Thanks! Simon |
![]() Quote:
Why do you have two threads on the same subject? Not cool and against the TOS. Maybe one of the mods can delete the duplicate thread. |
![]() Quote:
Simon, did you ever find a workaround? I'm experiencing the same situation / need.
Who are you talking to?
Back to the original issue, I see only 2 options:
1-find someone with an older setup, open the sessions and take notes or screen shots of the settings you need. 2-don't be afraid to just start over with a different but similar plugin. Some plugins did not make the transition intact(why those plugins won't come up on newer systems). If you consider how often before DAW's, when engineers had to resurrect a complete mix with next to nothing to go on, we are still miles ahead on recalling a mix. Personally, the few times this issue hit here(and it has), I simply take it as a challenge to better the old mix(and I usually do). That might happen due to newer and better plugin options, or it might be down to fresh ears ![]() If you mention the plugins you are wishing for, I bet the folks here will have some good suggestions for substitutes ![]()
Gigabyte X79/intel i7 3930K, 32GB RAM, HD/Native, 192 IO https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
Plugin settings disappear when reopening the session - PT 10.2 | Luke83 | macOS | 0 | 07-27-2012 09:06 AM |
Saving session plugin settings | David P. Green | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-24-2006 07:03 AM |
Importing a whole session's plugin settings | vetsen | Tips & Tricks | 2 | 02-14-2004 12:11 PM |
Is there a website that contains plugin settings for various RTAS/TDM plugins? | Fucius | General Discussion | 2 | 06-07-2001 03:43 AM |
