Old 02-10-2021, 09:11 AM
lavastudios lavastudios is offline
Default Avid folder insists on living in my Applications folder
Hey gang,
I just upgraded to PT 2020.12, and after running it I noticed that it has created two folders in my Applications folder (Avid and Avid_Uninstallers). I'm pretty anal about how I have things organised on my computer, and I do not like clutter in my Applications folder. I have all my audio programs in a subfolder within my Applications folder, and some time ago I gave up using any plugins or other audio software that stubbornly refused to be moved into that subfolder. So I moved these new Avid folders into my Audio Applications subfolder, but upon opening Pro Tools again, the Avid folder reappears in the main Applications folder. Does anyone know if there is any way to stop this happening? I'm aware this is a first world problem, but still.
In case it matters, here are my system specs:
MacBook Pro (Retina, 15-inch, Mid 2015)
Processor 2.8 GHz Intel Core i7
Memory 16 GB 1600 MHz DDR3
Graphics AMD Radeon R9 M370X 2 GB
Intel Iris Pro 1536 MB
OS X Mojave 10.14.6
Thanks!
Simon
Old 02-10-2021, 09:23 AM
JFreak JFreak is online now
Default Re: Avid folder insists on living in my Applications folder
You just need to delete the unnecessary folders after every update, if you are "anal" about it
Old 02-10-2021, 09:26 AM
Thanks for your reply JFreak. If it was only every update I needed to delete it, that wouldn't be a problem. Unfortunately, the Avid folder reappears in my Applications folder every time I start Pro Tools.
Old 02-10-2021, 09:28 AM
Does not happen here, curious why it happens there
Old 02-10-2021, 09:52 AM
Hmmm, weird. Does anyone else have this same behaviour with their setup?
Old 02-10-2021, 12:06 PM
paul_g's Avatar
paul_g paul_g is offline
Yes, I have Avid and Avid_Uninstallers in my applications folder.
5K Retina 27" (2020) iMac OS 12.6 Monterey
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2022.10
EuCon 4.8.6.41 / 2022.9.0.41
UA Luna
UAD 10.1.1
UA Apollo Twin X
Avid S1 / Fire10 - 21.8.1.0
HX Edit 3.50
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Songs from Outta The Blue
Old 02-10-2021, 12:54 PM
Of course you have, but if you delete them do they magically re-appear?
Old 02-10-2021, 03:32 PM
paul_g's Avatar
That's silly, why would I that? :)
Internal 2TiB SSD
Pro Tools 2022.10
UA Luna
UAD 10.1.1
UA Apollo Twin X
HX Edit 3.50
Dynaudio Monitors
Old 02-10-2021, 03:37 PM
If you were "anal" about things you might
Old 02-10-2021, 03:48 PM
Ben Jenssen's Avatar
You might see that it takes up a bit of disk space.
There is the Avid Virtual Instruments folder, over 3GB, and personally, due to a very small flash boot drive in my case, I have made a symlink that points to a copy on another disk, and it works fine.
But I'm shure these folders are are fundamental to PT hierachy, and I'm not surprised if they are recreated if they're missing.
The Pro Tools folder in Documents also behaves somewhat similar as I recall.
Life-long audio enthusiast and small studio owner. Retired.
Mac Mini M1, 16GB RAM. 512GBinternal(3000MB/s),2TB(1300MB/s),2TB(350MB/s)
MacOS 11.6.8. PT 2020.12.1 (2022.12 beta for testing)
Topping D50 DAC, Dynaudio BM6p, 2 x Artist Mix, SSL UC1, EuControl on iPad.
Move AIR Music Technology folder in Applications folder??? JCK43232 Pro Tools 11 7 03-23-2015 06:36 AM
Plug In folder/support folder corrupted?? jeffpardo Pro Tools 11 0 05-30-2014 08:46 AM
Why is there a VSTPlugins folder under my Avid folder? EnjoyRC Windows 1 10-28-2011 12:55 PM
Why can't I set my plugins root settings folder outside PT's default folder? RiF Pro Tools 9 4 09-26-2011 01:11 PM
Plug-Ins Alias folder points to wrong folder??? nod25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-26-2009 04:43 PM
