I would appreciate help with setting up my tracks in PT9 MP as I have very limited knowledge of MIDI setup and PT.
I would like to be able to control/record two instrument tracks using two external devices - 1 track controlled by 1 device: M-Audio Axiom pro 61 MIDI controller - connected via USB (Hypercontrol) Nord Electro 3 (monotimbral) - connected via MIDI OUT + MIDI IN of M-Audio FastTrack C400 - NE3 sends/receives MIDI data only on channel 1 by default I am trying to make Track 1 play and record the virtual Vacuum instrument via Axiom and Track 2 play the audio and record midi data of my NE3, so I set up the tracks like this: MIDI Input of Track 1 set to AxiomPro61HyperControl All Channels MIDI Output of Track 1 set to the plugin Vacuum 1-1 (automatically after setting the insert/plugin to this track) MIDI Input of Track 2 set to C400 Channel 1 MIDI Output of Track 2 set to none or to C400 Channel 1 Audio Input of Track 2 is set to C400 Analog 1-2 Input. I end up with two undesired results depending on whether the MIDI Thru opiton is selected or deselected. 1. MIDI Thru selected: if the last clicked/selected MIDI Output was Track 1 Vacuum 1-1 then it Axiom plays this intrument but no MIDI is recorded on this track, NE3 plays both the NE3 sound plus the Vacuum plugin sound and Track 2 records MIDI data. if the last clicked/selected MIDI Output was Track 2 C400 Channel 1 then both Axiom and NE3 play only NE3 sound and only Track 2 records MIDI data. 2 MIDI Thru deselected: Track 1 is mute - no midi input from Axiom gets to the Vacuum plugin. Track 2 plays and records MIDI data when I play NE3. I believe that there is a way to achieve what I was trying to do and I hope that my English is good enough for you to understand my description. Thanks a lot for any help. |
MIDI Input Selector Not Working on Instrument Tracks? | kafka | MIDI | 0 | 08-02-2011 07:50 PM |
RTAS instrument not receiving midi input | parke02 | Pro Tools M-Powered (Win) | 9 | 12-08-2008 08:10 PM |
Midi Input drops out on just Instrument tracks? | Hp trigger | Pro Tools TDM Systems (Mac) | 0 | 09-14-2007 05:40 PM |
No Instrument Insert on Instrument tracks | Bazbo | Virtual Instruments | 4 | 03-01-2007 07:00 AM |
No sound from "Aux Input" and "Instrument" tracks | slowdude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-25-2005 04:46 AM |
