Mad tracks! Should I track in stereo? Mono?
Not exactly how I wanted to word the question, but - Everyone here seems bent on tracking one instrument per track. What happens if you have a bunch of stereo patches on your synth that you'd like to track? With an 001/6.1, you're limited to 32 tracks, so where do I go from there?
Imagine, I'm tracking a MIDI composition (using all available 16 MIDI channels) and within those tracks exists stereo patches. Could you imagine me just using all 32 audio tracks alone becuase my 16 MIDI tracks include stereo patches? This wouldn't make sense at all. So after looking at a lot of the example files, it seems as if many choose to track guitars and bass in MONO. I guess the appropriate question would be what should we track in MONO and what in stereo?. It's obvious that many stereo patches sound good ONLY in stereo. It should be pointed out that Vocals and Acoustic instruments are also in my compositions, but MIDI is the focus of this thread.
Macbook Pro 15" (Mid 2014) 16GB RAM 512GB SSD Pro-Tools 12 2.5GHz i7 Quad Core |
Re: Mad tracks! Should I track in stereo? Mono?
Track the Midi, not the audio. I believe you have something like 128 midi tracaks. Use an external mixer to mix the audio from the synths down to a stereo mix, and bring that back into PT on a stereo aux track, whcih do not count towards the 32 total audio tracks. Mix the synths using the Midi tracks.
i record all my sequences in MIDI into Pro Tools then record the individual tracks and mix. Then if I run out of tracks I'd just bounce all the drums or horns etc to a stereo track. If the tracks u bounced aren't working u can pull them from the sound files list into new tracks and bounce again or re-record them from the MIDI tracks.
It's finally starting to come together |
Recording the midi and audio tracks is a waste, you're esentially recording it twice. Record the midi and simply route the audio back in via aux tracks, no need to record unles you have to further tweak the sounds, whcih you can do in the sound modules.
Okay, this I've done before (use the Aux tracks for MIDI), but I notice that my mix sounds MUCH better when I record the MIDI to separate tracks rather than try to cram a whole mix into two inputs.
Where, you sound like an extremely knowledgeable person, but if I were to send my mix in for mastering, wouldn't they want my MIDI tracked as audio on individual tracks for tweaking if necessary (mixing on the post production side of things). Thanks
Your MIDI tracks would be mixed into your final 2 track mix via a stereo Aux track.. so you'd still be giving the mastering engineer a final stereo mix.
If you don't want to mix the MIDI tracks live externally.. you can still buss them via Aux tracks and record sub mixes inside Pro Tools.. you have 128 audio tracks which can be enabled or disabled.. use them and do sub mixes. Rail
Submix to multiple aux's as rail suggests, or use an outboard mixer for your midi audio tracks. |
- Jason |
This may have been mentioned but piling up midi tracks leads to built up latency from track to track. Since MIDI is serial, data is sent linearly so if you have more than 4 midi tracks, the last track will be noticeably delayed. This can easily be fixed with midi offset but this is an art. And as you add more midi tracks, they get progressively more out of time. I agree that for a couple of tracks, I would keep them thru an aux but as they build up, I just record them to an audio track.
Cliff Stendel -iMac 5K 32g
-PT12. HDX -HD I/O 8x8x8. -HD Omni -Avid S3 -API 2500 -API 5500 -UA 2-1176 -UA 2-610 -Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96 -Bricasti M7. -Joe Meek channel. -Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more -Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12 |
That's an oversimplification.
Yes, MIDI is serial. But the delay isn't caused by multiple tracks directly. Noticeable delays occur when you try to do too many things simulataneously, regardless of the number of tracks involved. A 10 note piano chord, all played on one track, is actually a very fast stacatto, over a period of no less than about 10 ms. Quote:
Quad 2.5 G5, 4.5G RAM |
2 mono tracks to 1 stereo track | Pass | Tips & Tricks | 19 | 06-01-2016 10:09 PM |
making mono track into stereo or double mono in PT7LE | VeganMuso | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 02-02-2012 05:36 AM |
A question about mono/stereo plug ins on mono tracks. | rockguitarist1255 | Pro Tools 10 | 2 | 12-24-2011 07:33 PM |
Mono audio tracks + stereo aux track = panning issues! Help please! | shotgunjoe | Pro Tools M-Powered (Win) | 2 | 03-31-2011 03:07 PM |
Drum Overheads: 2 mono tracks or 1 stereo track? | SoundReplay | Tips & Tricks | 17 | 10-14-2009 03:58 PM |
