Old 10-05-2010, 04:55 PM
browniespeaks browniespeaks is offline
Default Keyboard shortcut to move curser to end of selection?
PT 8.0.4 LE on windows with no expansion packs
Thanks in advance
Clifford Brown III
Brown Audio Solutions & Services
www.brownaudio.com
Old 10-05-2010, 05:20 PM
elicious elicious is offline
Default Re: Keyboard shortcut to move courser to end of selection?
w
e
ihatetyping
Old 10-05-2010, 05:37 PM
tonepad tonepad is offline
tab goes forward region boundary by region boundary
Ctrl tab does the same in reverse
There are other cool tab with modifier functions, but I am sure you've found your manual or PDF by now haven't you?
Carry on
My day job:
Wilson Dyer MPSE
Sound Supervisor: NCIS Los Angeles, CBS Television
Old 10-05-2010, 05:45 PM
thanks for replies. I should have been more specific. I am looking for something that will work while tab to transients is engaged. none of the above work.
Clifford Brown III
www.brownaudio.com
Old 10-05-2010, 05:53 PM
The Weed's Avatar
The Weed The Weed is offline
Try "L" to move the Cursor from right to left and the quotation mark (') to move the Cursor from left to right. Remember that fade boundaries and sync points are considered region boundaries as well.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 10-05-2010, 06:05 PM
[edit]
actually L and ' are rw and ff just like 1 and 2 on number pad. hrmmm.
thanks a bunch couldn't remember for the life of me and only online is through phone.
Clifford Brown III
www.brownaudio.com
Old 10-05-2010, 10:40 PM
bump
Clifford Brown III
www.brownaudio.com
Old 10-06-2010, 05:38 PM
The Weed's Avatar
Sorry, on my computer "L" and the (') move the cursor left and right. Is Commands Focus on? Is the Numeric Keypad set to transport?
Cheers,
SonoBus
Old 10-07-2010, 05:17 AM
The Weed's Avatar
My apologies, I did not have "Tab To Transient" turned on. If that is on then "L" and (') work the same as "Tab" moving the cursor to the next Transient. I would suggest making a Feature Request to have "L" and (') continue to operate normally when "Tab To Transient" is on so that you can easily move the cursor to the next boundary rather than the next Transient.
If you just want to move to the next region you can try these shortcuts:
Start + Tab selects the next region to the right of the cursor (note: in this case fades are considered regions too)
Start + Ctrl +Tab selects the next region to the left of the cursor (note: in this case fades are considered regions too)
Start + Shift + Tab selects from the cursor to the next region to the right of the cursor and holding down Shift + Start and repeatedly hitting Tab continues to add regions to the selection (note: in this case fades are considered regions too)
Start + Ctrl + Shift + Tab selects from the cursor to the next region to the left of the cursor and holding down Shift + Start + Ctrl and repeatedly hitting Tab continues to add regions to the selection (note: in this case fades are considered regions too)
Cheers,
SonoBus
Old 04-29-2022, 11:43 AM
audioteck818 audioteck818 is offline
Is UP arrow for me.
Keyboard shortcut to move audio clip up/down a track PhilipKapadia Pro Tools 7 01-23-2024 12:23 PM
'write automation to selection' keyboard shortcut Ben Wood Post - Surround - Video 8 06-19-2019 12:42 AM
Can you move between patches using keyboard shortcut? sponge Pro Tools SE and Essential (Win) 0 08-13-2012 10:43 PM
Keyboard Shortcut - New Memory Location - Selection Andi R Pro Tools TDM Systems (Mac) 12 05-19-2010 09:26 AM
