#21
Re: CPU Overload! Help!!!
#22
PT 12.8.2 macOS Sierra 10.12.6 iMac (27-inch, Late 2012) 3.4 GHz Intel Core i7 16 GB 1600 MHz DDR3 Interface Focusrite Saffire PRO 24 |
#23
#24
Get a drive with 2 firewire 400 ports, no RAID and try it again - I bet your success rate goes up exponentially. |
#25
What Alan Z means by saying he gets the 6101 all the time and then it runs fine for a long time is that the error happens once to a fresh session and then never again during that session even if you run that session for hours. It's like you get through the error and you're home free...until you reboot pro tools. This glitch isn't so bad, although i was recording an acoustic duo yesterday and during a great vocal take BAM 6101...kind of embarrassing. Like Alan Z said, after the glitch happens, you don't need to make any changes to your session. It's definitely not really overloading. I'm running an iMac 2.93 GHz Intel Core 2 Duo with 4 GB of memory. My software is up to date. I'm using a M-Audio Firewire 1814, plugging it in with a firewire 800 cable. I'm recording onto a WD My Book that's usb. Hope you can help! |
#26
USB drives are not supported in any form.... FYI
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
#27
CPU overload continued.... I have the new macbook pro 13" and it only has 1 FW port and 2 USB all on same bus. I get the error all the time especially when running omnisphere rtas in PTs. I saw other threads that suggested getting a FW express card but i have no slot for it. I have my core sound library on my external drive thru USB and my I/O FW 410 thru my 1 FW800 port. I just added 4gig of ram and that didn't help to much. suggestions??
#28
J |
#29
no usb connections. just like other postings tried most solutions. i would try eric's solution with separating external drive and FW 410 but the new macbook pro 13" dont come with that express card slot. all i have to work with is 1 FW port and 2 usb on same bus. unless something else could be causing error?? but it sounds like all the postings on this subject that there has to a main cause for this, huh?
#30
After crashing pro tool, installing drivers and reinstalling those properly(updates),
it runs in 10.5.5 Leopard on a imac, the midi is finally recognized,that's ok. However, many peeps know that a Imac core audio system can generate CPU overload. Don't worry, that's the same with Logic 8. U can have a little sound card or a digi, the same f... window appears on the screen. For Logic I entered a big code wich limits this CPU overload, or more, regulate the work of the processor.This is possible with the apple script editor, then save it as an app. Maybe, instead of waiting for new updates, osx users would have to do the same script in order to make PT run a better way. pro tools LE 8(and mpowered/mbox2 usb)before. The best issue is anyway to install a DSP or adapted PCI card,but so so so expensive hardware solution. PLEASE DIGITEAM, help us... |
CPU Overload | Jmissy87 | Pro Tools 10 | 4 | 05-13-2013 10:04 AM |
cpu overload | maxidud999 | macOS | 3 | 03-14-2013 06:48 PM |
CPU overload | aldoriba | Pro Tools M-Powered (Mac) | 1 | 12-09-2008 05:25 AM |
CPU overload | marcvise | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-06-2008 12:56 PM |
CPU overload | Raggi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-20-2005 02:49 PM |
