2022.9/Melodyne: how to know which clip I'm editing?
Is there any way to tell which clip I'm editing in the Melodyne window? E.g. the Clip Effects tab has the clip's name in the top left. But the Melodyne tab has nothing there. Can anyone point me in the right direction here? How can you tell?
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest * Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1 * PT 23.6 + Ableton Suite 11.3 * Soundtoys + Valhalla + Fabfilter + Spitfire * RME Fireface UCX II ~ Arturia Keylab Essential 49 * various clarinets, trumpets, flutes, plucky stringy thingies |
Re: 2022.9/Melodyne: how to know which clip I'm editing?
In the Melodyne Tab -> Options Menu -> check "Follow Selection in DAW" and "Zoom to Selection In DAW".
Kerry Smith http://apothekerry.com Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro |
Yes! That is so cool, can have vocal comping undone and still use Melodyne. Changes in vocal comping easily tunable. Very very VERY cool.
Thanks for the answer, but that actually works a little bit strangely. If you're Melodyne editing two different tracks, and you click in one or the other in the timeline, it doesn't actually change what is showing in the editor pane. If you actually *select* something in the timeline, then it switches. But if I'm working on a phrase between two tracks, it seems like I should be able to just click to switch. That's how the MIDI Editor works, at least...
Had not thought about that, now I can comp and tune in one go, very very useful, will try that tonight.
Pro Tools 2022.9 UAD Apollo 16 (v10.1) Dell XPS 8940 (i5-11400) Win10 www.studiodrumtracks.com www.doubledogrecording.com |
In this case, I'd recommend putting the two mono tracks together into one stereo track, and then tuning that. You can just make a new stereo audio track and drag the two mono clips (together) into the stereo track. This way the exact same adjustments are made to the two channels, and you won't end up with tuning differences or phasing issues. You can then process them separately with multi-mono plugins, or you can tune them and then drag them back into mono tracks, whichever works better for you.
2022.9- Moving Clip FX window back to top | SoapOperaGuy | Pro Tools | 30 | 11-15-2022 02:19 PM |
2022.9 Melodyne Analyzing freezes PT | pmueller | Pro Tools | 8 | 09-29-2022 12:20 PM |
Value disappears when changing Clip Gain in 2022.9 | home_studio | Pro Tools | 3 | 09-28-2022 11:37 AM |
Melodyne Pitch Correction and PT Ultimate 2022.5 | Soliloquay | AAX Plug-ins | 1 | 07-09-2022 09:24 PM |
Editing duplicate clip alters original clip | screename1011011 | Getting Started | 4 | 02-24-2016 07:03 AM |
