Old 08-26-2022, 09:05 AM
postman56 postman56 is offline
Default Best way to bring in a Zoom Audio into D Command
I'd appreciate any suggestions of the best way to do this:
I need to get a audio feed off my Focusrite box I'm using to connect for Zoom calls into the D-Command so the vo talent can listen to their direction. I've just currently have been using an external mic and opening the talkback when they are directing direct of the laptop.
I'm using channels 1& 2 output of Protools and C2 Main in the cue off my headphone amp, as a send into the Focusrite and down to the client.
Can I use a analog input off my 1/0's possible, but then I'd have a loop?
Any suggestions would be greatly appreciated if anyone have some experience.
Ken
Canada
Old 08-28-2022, 03:35 PM
Led Led is offline
Default Re: Best way to bring in a Zoom Audio into D Command
Source Nexus by Source elements. You put it as a plugin over an aux in Pro Tools, and set it as the in and out in Zoom audio settings. Then you send to the aux, it feeds zoom, and you have the aux's output routed to main out and cans and you and talent hear the people on zoom. It's like 10 bucks or something. I use it all the time when people want to listen in. There's also a high res web app for listen in and talking back, but it only works on chrome browser.
zoom key command blastula Pro Tools TDM Systems (Mac) 2 05-05-2015 02:01 PM
Key Command to bring AudioSuite window to front? Irl Sanders Pro Tools 10 2 06-17-2013 05:55 PM
Vertical zoom to show default waveform height (Audio) with D-Command ? Hanswurstlsepp ICON & C|24 0 06-30-2011 03:55 AM
Is there a key command to bring the new piano roll editor pane up? Ru_C Pro Tools TDM Systems (Mac) 2 03-14-2011 11:04 PM
Can you bring an audiosuite plugin under d-command surface control paulroberts ICON & C|24 0 03-22-2010 01:24 PM
