#21
Re: Paulstretch AAX plugin
>What order should the plugin be on a track if using a software instrument?
AFTER the software instrument. If before, it will capture no audio. >Should the track be record enabled or is this from the capture button in Paulstrech? BOTH the track must be enabled and capture button in Paulstretch to take record-enabled track audio or VI input and be captured by PaulStretch >Or should it be on a different track with a send from the instrument track and the armed/not armed or capture button? This simply comes down to your needs or other uses of the signal flow. Simplest way I got it to work was having a 4 bar loop of a bassline. I played the loop in PT on an Audio Track. AAX Paulstretch was on that track as an insert. As the loop was playing and looping, I hit capture. Following the other setup described recently above that also took me about 6 minutes (time was longer, you could say stretched, after I started having fun!), it was working right away. It did take me a bit of button mashing to get the audio and PaulStretch playing in PT and "capture" but basically if an audio signal is going "into" that plugin, and transport and Play when running are both running, then "Capture" takes the signal. You can load a file separately, otherwise the capture button doesn't "auto read the selection" or in other words it is a "live" capture. I used the original back in 2011 or something, I think. It was fun as an Audiosuite. This version is neat too! Thanks for the prompt.
___ >> me: nednednerB // ||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music // ||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 // ||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock // ||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR ||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts // |
#22
Paulstrech is awesome! Glad to see it back, I only messed with it on PC over a decade ago, but one great thing it does is stretch things out looooong without many artifacts. What I'll do is I'll take a section of chorus vocals (usually a single, held-out note) and stretch it out for the whole duration of the chorus and mix it in the background or put it in another part of the song like the bridge or something as a pad-like effect.
#23
Well, now I have to try this thing.
#24
~Will |
#25
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card. OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW. Almost every plugin |
#26
iMac (2020: 3.8 GHz 8-Core Intel Core i7, 32GB), OSX 13.1 (Ventura), Pro Tools 2024, UAD Apollo 8, UAD-2 Quad Satellite DSP Accelerator, 2 x Lacie Thunderbolt SSD (250GB), Seagate Backup Plus Drive (4TB). |
#27
Thank you for giving the solution! ❤️ Without it everything dies.
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2 https://www.waves.com/r/djgsi6 |
#28
thank you for the heads up about aax version of paulstretch. I was introduced by some trailer/sound designers years ago.
Forget about the elistists here. we have a responsibility to share. I dont know where i'd be if it werent for people like Rail or Tony S who guided me along the way. I've been here for over 20 years and am thankful for all of the help. |
#29
LDS, You are correct in stating that I should have tried everything you suggested before coming on to the forum. I had, and I had gone down the route that you and nednednerb have suggested. For me it did not work. I think what was upsetting was that you and Ben assumed that I hadn't tried. The standalone version works fine but the plugin I am still having problems with.
I have had a response from Sonosaurus and there is a bug but for me I don't think that is the problem, so I will keep playing with it.This might. help others. From Sonosaurus 'There is a bug in the current version that sometimes prevents the output from working until you toggle the stretch-enable button off then on again (the "power" button looking thing next to the Stretch amount slider). Just in case you have it all set up (with input monitoring enabled on the track) correctly and it still doesn't work' And thank you nednednerb for the best and most useful reply. |
#30
It is also as far as I know unique - not sure though. Worth checking. Let's pay respect to Paul.
Free beer tomorrow !! - but until then - we're stuck in the present moment |
Schoeps DOUBLE MS PLUGIN (2018) SURROUND PLUGIN FOR AAX finally available! | bartosz idzi | AAX Plug-ins | 1 | 12-16-2018 03:49 AM |
Bug: When selecting a favorite plugin insert, the plugin above the one selected opens | DJ Hellfire | Pro Tools 12 | 35 | 08-22-2017 08:05 PM |
Trim DSP plugin uses CPU power when inserted before a Native plugin? | BEN6732 | Pro Tools HDX & HD Native Systems (Mac) | 11 | 03-30-2016 03:36 PM |
v control (v2) plugin encoder cannot instantiate plugin screen in PT10.0.1 | klyg | Artist Series | 2 | 02-29-2012 10:50 PM |
Vocal plugin needed to change voice, what is the best plugin | Logicdance | Digidesign Hardware & Software | 0 | 03-13-2007 04:26 AM |
