Old 06-07-2022, 09:49 AM
psdrummin psdrummin is offline
Default Hardware setup
Monterey 12.4 - PT 12
My hardware setup won't recognize my protools duet interface like it always has? My Apogee says "waiting for device" - it will only let me select built in microphone? I am at a standstill
Help me Obi Wan
Old 06-07-2022, 10:59 AM
Default Re: Hardware setup
Pro Tools 12 on Monterey is way outside any supported configuration. What changed? Did you just upgrade macOS?
Know the compatibility matrix should you.
https://avid.secure.force.com/pkb/ar...tibility-Chart
Know device driver comparability should you as well.
https://avid.secure.force.com/pkb/ar...uartet-Drivers
I find your use of these unsupported configurations not logical.
Old 06-07-2022, 12:46 PM
Top Jimmy's Avatar
Would this have anything to do with the privacy setting that blocks access to the hardware I/O until explicitly granted?
James Cadwallader
Old 06-07-2022, 01:43 PM
Sure that's could be an issue, if everything else was close to working. And for this to cause a problem it would require a new driver install and/or a new OS install (otherwise permissions are grandfathered in). Which might be what happened. But that does not get around that this is way the heck outside a supported configuration. And if so much changed recently, are we dealing now with an Apple silicon Mac? (which drivers would not install on, but who knows if that was tried if that was tried).
We are not getting the full story, starting with a lack of any info about hat mac this is on and what exactly changed? Why? Ceti eel lava at the ready.
Hardware Setup App LightUnderTheDoor macOS 9 01-03-2015 06:50 PM
I/O setup doesn't reflect my hardware setup devapro Pro Tools TDM Systems (Mac) 7 12-30-2006 11:16 AM
le 5.3.1 Hardware setup MichaelAS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-02-2004 04:57 PM
+4 -10 hardware setup Jason Lowe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-29-2003 12:01 AM
Anyway of keeping the Hardware Setup...Setup!!! Imagine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-14-2003 03:26 PM
