Old 04-30-2022, 10:04 PM
audiolex1 audiolex1 is offline
Default EdiCue V4 is out
There are some nice added features.
Great implementation of characters from the scripts for creating the template for pro tools cueing.
Check it out.
https://www.soundsinsync.com/products/edicue
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors
PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card.
OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW.
Almost every plugin
Old 05-06-2022, 04:49 AM
mfranken's Avatar
mfranken mfranken is offline
Sounds In Sync
Default Re: EdiCue V4 is out
Just released #EdiCue v4.0.1. with the following bug fixes and minor changes:
  • Fix to stop 'File audio pull up/down rate out-of-range' error while loading PTX files.
  • Fix to allow clips to be appended with 'AP' tag when loaded from PTX files.
  • Fix so the PTX file load option 'Only load active tracks' works.
  • Fix to show a 'Custom Cue Number' column in the Cue List window when data is loading from a PTX file. Click Details next to 'Cue Count' on the main tab.
  • While exporting a PTX file containing the CCNs in the clip names, the 'Cx' tag is now only exported in active clips.
  • While importing a PTX or PT Text file, mute or inactive clips are now ignored while checking CCNs in clips.
  • Change to the way EdiCue associates with PTX files on macOS to stop a PTX double-click from opening in EdiCue.
To download the app installer, go to http://www.soundsinsync.com/download/
Mark Franken, MPSE
Dialogue editor/supervisor IMDb
Creator of 'EDI' applications for sound post editors
HTML code is On
EdiCue v3 released mfranken Partner Announcements 13 01-05-2022 09:58 PM
EdiCue v3 - Emmy Award winning ADR cueing app major update has been released mfranken Partner Announcements 0 08-04-2019 09:16 PM
