New article on PT11 metering
A little more info than we had before, along with the most close-up picture of the new meters that we've seen so far:
http://www.avidblogs.com/pro-tools-1...ything-louder/ |
Re: New article on PT11 metering
From my understanding, all extra metering is HD only, Native users would only get the metering already present in Pro Tools 10
System Specs: http://duc.avid.com/member.php?u=108915 Audio Reel: http://www.wacc.net/ https://soundcloud.com/13guatamas13 |
"Now, in Pro Tools 11, you have a choice of precision metering – 17 different scales in 11HD, and 4 in non-HD 11." |
Are we safe assuming blog text is inherently accurate? It would be nice to think so.
I wonder whether the metering ballastics are hard wired? It would seem oddly archaic coding if so. Avid would more likely have defined the set of parameters needed to properly describe all possible aspects of metering ballastic properties generically. Having done that, the current list of metering types is simply a list of presets, each having a set of defined values for each parameter. This methodology would allow more metering options can be easily added later, once their ballistics have been properly measured.
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10 iMac 2012 27", 3.4ghz i7, 32gb RAM OS 10.14.6 Digi 003 Console for control surface only, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors. Pro Tools 2022.4, Media Composer 8.9, Sibelius 8.7, Cubase Pro 11, Wavelab Pro 11, Logic Pro X 10.5.1, Mainstage 3. Various apps, soft synths, FX plugins. Plenty of hardware synths, rack gear, microphones etc. And then there's the studio ;-) |
Nigel - I was under the impression that this is an official Avid blog ... in which case (and in the circumstances specifically regarding the proposed feature differences between the HD and non-HD products), they would be crazy to let out that sort of detail unchecked, don't you think?! And it is quite specific by fixing the number of 'vanilla meters' (now there's a new term!) at four?!
That would be my thinking too ;-)
Maybe vanilla meters will be lighter in colour too?
But I want chocolate! And after spending all those dollars over the years with Avid, I want it for free....and I want 6 not 4.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
The ballistics of PT's meters has always been weird. The release is WAY to fast for example. This is fixed in 11.
I really like the look of these new meters. The ability to set different meters for masters is something which I'll find very useful for post production mixes where I currently have to use a PPM metering plug-in on the master. I know that a lot of people prefer to use proper hardware PPM meters for broadcast work where accurate metering is essential. Personally, I've found the PPM meters in the Phasescope plug-in to be good, and none of my mixes have been knocked back so far.
I'd be interested to know the thoughts of people working in post regarding the use of software based PPM metering vs the hardware equivalent. |
PT11 to PT11 HD Native upgrade without hardware? | kirkbross | Pro Tools 11 | 2 | 11-04-2013 03:10 PM |
PT11 cpu usage metering | musicman691 | Pro Tools 11 | 14 | 07-08-2013 03:26 AM |
Pre-Fader Metering vs Post-Fader Metering | teacherman | Pro Tools TDM Systems (Mac) | 3 | 01-29-2008 07:33 PM |
