Old 04-30-2021, 08:57 PM
Jedddelaland Jedddelaland is offline
Default Pro Tools Crashing issue
Hello all!
I am brand new to the community and to using pro tools.
i have recently downloaded pro tools 2021 on windows 10 using the focusrite 212 2nd gen.
once i open pro tools and select create (either from template or not) pro tools will load to what i assume is main editing screen and then immediately crash no matter what i do.
i have searched online and cannot find anything that is of help to me. i have also downloaded the recommended driver as well as the updated focus rite driver.
any help would be greatly appreciated!
have a great day, thanks
Old 04-30-2021, 10:33 PM
sw rec sw rec is offline
Default Re: Pro Tools Crashing issue
Need system info!!
https://duc.avid.com/showthread.php?t=300050
Old 05-01-2021, 12:30 AM
i have just purchased the surface laptop 3. its literally brand new the only install i have done is trend security, driver one support and pro tools.
here is the sysytem info
(i have the 8g ram version)
Dimensions
Surface Laptop 3 13.5”
308 mm x 223 mm x 14.5 mm (12.1” x 8.8” x .57”)
Surface Laptop 3 15”
339.5 mm x 244 mm x 14.69 mm (13.4” x 9.6” x .57”)
Display
Screen: 13.5” PixelSense™ Display
Resolution: 2256 x 1504 (201 PPI)
Aspect ratio: 3:2
Surface Pen* enabled
Touch: 10 point multi-touch
Screen: 15” PixelSense™ Display
Resolution: 2496 x 1664 (201 PPI)
Aspect ratio: 3:2
Memory
8GB or 16GB LPDDR4x RAM
8GB, 16GB DDR4 RAM
Processor
Quad-core 10th Gen Intel® Core™ i5-1035G7 Processor
Quad-core 10th Gen Intel® Core™ i7-1065G7 Processor
AMD Ryzen™ 5 3580U Mobile Processor with Radeon™ Vega 9 Graphics Microsoft Surface® Edition
AMD Ryzen™ 7 3780U Mobile Processor with Radeon™ RX Vega 11 Graphics Microsoft Surface® Edition
Security
Firmware TPM
Enterprise-grade protection with Windows Hello face sign-in
Software
Windows 10 Home4
Microsoft 365 30-day trial
Sensors
Ambient light sensor
Old 05-01-2021, 01:04 AM
The system requirements for Protools 2021.3 & 2021.3.1 states that the minimum RAM is 16 GB and 32 GB is recommended. Having said that, I have an separate 8GB 12" Macbook and Protools 2021.3.1 seems to run okay on it. Perhaps Windows is more strict with the minimum RAM requirement.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 05-01-2021, 04:02 AM
Dimensions
Display
Aspect ratio: 3:2
Aspect ratio: 3:2
Memory
8GB, 16GB DDR4 RAM
Processor
Security
Firmware TPM
Software
Windows 10 Home4
Sensors
I'm confused with these specs. How many computers do you have? You're showing specs for two different machines. Either way around 8 gig ram isn't going to be enough to run PT.
Jack
QAPLA!
Old 05-01-2021, 05:52 AM
EGS's Avatar
EGS EGS is offline
Originally Posted by musicman691 View Post
...8 gig ram isn't going to be enough to run PT.
It'll run, but barely... Audio only, no VI's, no video, not a lot of tracks, not a lot of plugs.
Click for audio/video demo
Click for resume
Old 05-01-2021, 07:53 AM
Also, which processor? You didn’t give us YOUR system specs. Many have said that their i5 machines are working, but Avid highly recommends an i7. Have you done all of the recommended optimizations?
https://avid.secure.force.com/pkb/ar...ndows-10-Guide
Old 05-01-2021, 10:26 AM
paul_g's Avatar
paul_g paul_g is offline
Here is what I see countless times on this forum. Folks trying to run a professional, industry standard DAW on a low end system. Throughput, CPU, Bus Speed, Disk I/O, RAM, minimizing all potential nannies, processes, bloatware... all factors when running sessions in Pro Tools.
For ProTools, I highly suggest scoping out a PBA (Purpose Built Appliance - hence a system that only does one thing, Pro Tools), especially if you don't want to fuss with things not running, crashing, etc...
5K Retina 27" (2020) iMac OS 13.6.5 Ventura
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2024.3
EuCon 4.8.6.41 / 2023.11
UA Luna
UAD 11
UA Apollo Twin X
Avid S1 / Fire10 - 21.8.1.0
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Check my Music out here:
Paul G YouTube
Paul G Bandcamp
Old 05-01-2021, 11:14 AM
The Weed's Avatar
The Weed The Weed is offline
This^^^^
If you really don't need Pro Tools, get Reaper and get to work.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 05-01-2021, 12:46 PM
K Roche's Avatar
K Roche K Roche is offline
Dimensions
Display
Aspect ratio: 3:2
Aspect ratio: 3:2
Memory
8GB, 16GB DDR4 RAM
Processor
Security
Firmware TPM
Software
Windows 10 Home4
Sensors
Ok for the future rather than just copying and pasting info from the computer website List Your actual computer and just list the Ram-processor- OS version --PT version and your interface See my sig line below.
Back to your op First you said you downloaded the Focusrite updated driver But did you install it ? it so then ::
When you go to launch PT ,,,Hold down the (N) key on your computer keyboard then launch PT It should open a screen that asks you if you want the Focusrite as the Playback engine . (in other words try to find out if PT even sees the Focusrite as a Playback engine or Audo playback device
If PT sees the Focusrite and you have it selected THEN ::
What I would try next is trashing you preferences.
If that does not work then try uninstalling PT and the Focus rite driver
Then install the Driver first,,, then install PT ..
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Another "Pro Tools crashing" issue Scott.Brownlee Pro Tools 2018 10 11-24-2019 03:36 PM
Crashing during startup issue Mr_Nice_Guy Pro Tools SE and Essential (Win) 5 12-13-2010 01:47 PM
11r & pro tools le issue - system crashing Jasconito Eleven Rack 2 11-19-2010 08:19 PM
Bizzare Crashing Issue... Tim Hoeksema 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-18-2007 01:10 PM
Not a power harness issue, but a lot of crashing. reztowel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-25-2004 09:22 PM
