MBox 3 Mini - Static and Noise Issues
I just purchased a NOS MBox 3 Mini for use with a Windows Desktop.
Installed Pro Tools Express as well as current M Box driver. Basically when trying to monitor sound through the MBox I get very loud shots of static and noise. When I create and or open a session I get the same static and noise issues anytime there is audio coming through. Whether I attempt to play a track with audio on it or engage the "Record" button and attempt to record to a track. Same issues. Any help or troubleshoot would be appreciated.
Early 2008 Mac Pro 2 x 3.2 GHz Quad-Core Intel Xeon 10 GB 800 MHz DDR2 FB-DIMM Mac OS X Mavericks 10.9.1 Digi003R+ |
Re: MBox 3 Mini - Static and Noise Issues
Same thing is happening to mine all of a sudden spikes of some sort static short bursts Unuseable like this
Ahh after digging i found some info..What a load brand new interface and it dosent support USB 3.0 which has been out for years.If i had of know that i wouldnt have bought the damn thing! USB 3.0 ports on Windows 7 are not supported. |
Thanks. I read that on the Avid support page as well.
http://avid.force.com/pkb/articles/e...t-Track-family Curious as to a work around if this is in fact my issue? Either a setting adjust in the BIOS for "legacy usb" or perhaps connecting through a USB 2.0 hub before going into the 3.0 on the computer. Essentially dumbing it down. Hopefully here is a fix out there being this was all just recently purchased. I a a Mac user for my studio setup. These issues aren't anything I normally experience. The windows machine is functioning as an alternate for client use. So far it's a bust.
Well after fiddling around its def the 3.0 port switched to 2.0 and not a scratch or noise BUT! I also disabled my onboard sound card and moved my mouse and mpc studio to the other side of my laptop and the mbox is on the other side alone.As soon as i plug my mouse up on that side with the mbox the noise comes right back.So maybe a powered hub is the way to go.As of now i have 3 usb ports that are unusable because of the mbox needs a whole side alone.
I experienced the same problem with an Mbox Mini: lots of static on the output (it was plugged into a USB 3 hub). After doing a search and seeing this page, I tried plugging the Mini into a USB 2 hub that was plugged into a USB 3 port, and found that it worked fine that way.
Stabs of Static/White Noise from Mbox Mini 3 | onedope | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-17-2012 08:21 PM |
A few Issues I'm still having Static noise and 48khz sample rate | Caatalyst | Windows | 16 | 01-18-2012 04:07 AM |
Nothing but static from Mbox 2 mini | pfledderjon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 05-14-2010 12:58 PM |
Mbox 2 mini static | ProtaJay | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-04-2009 03:58 PM |
MBOX 2 Mini Static | acuraboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-10-2008 04:15 PM |
