Old 07-28-2021, 09:27 PM
PWR PWR is offline
Default Artist Control Not connecting/controlling Protools
Hello everyone,
This is my 2nd attempt at posting as the first one didn't work.
I am sure I am doing something very silly and obvious here but...
I have just upgraded my home studio computer
Mac Pro rack 2019
Big Sur 11.2.3
Protools 2021.6.0
Eucontrol version 2021.6.0.181
Eucon Version 4.7.9.181
Basically, the artist control is connected to the computer, its set up by a static IP, I see it in the eucontrol and it says 'welcome to artist series' on the screen, but when I open a session...NOTHING, no tracks showing and no faders up to 0....Yes eucon is enabled in protools peripherals
I have checked, double checked then triple checked all my security prefs, I have rolled back to protools 2020 and I am using the same cable to connect directly to the machine that I was before.
I am baffled, even the studio tech guy from my work is baffled.
Thanks in advance for any help
Paul
Old 07-29-2021, 03:02 AM
priorytools priorytools is offline
Default Re: Artist Control Not connecting/controlling Protools
Have you enabled eucon in pro tools peripherals ?
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 07-29-2021, 04:14 AM
PWR PWR is offline
Hey Priory,
Yes I have
Thanks
Old 07-29-2021, 05:02 AM
Ok.
In the Eucontrol app, Surfaces have you “added” your surface so it appears in the “my surfaces” section?
Old 07-29-2021, 05:07 AM
PWR PWR is offline
Originally Posted by priorytools View Post
Ok.
As mentioned it is connected and visible in eucontrol and shows up in my surfaces. It is connected and showing exactly as it should, except for the fact that when I open protools it doesn’t react to it.
Old 07-29-2021, 05:33 AM
PWR PWR is offline
Ok.
Hey,
Yea I have, it’s all connected and showing up as normal.
Thanks
Old 07-29-2021, 07:20 AM
EddieJones's Avatar
Its your Big Sur version 11.2.3 many issues. Update to 11.5
Old 07-29-2021, 02:38 PM
PWR PWR is offline
AMAZING, Thanks, that has worked.
Artist Mix not connecting LelioP Artist Series 14 12-06-2020 02:02 PM
Artist Mix controlling plugins mikeyman Artist Series 2 04-17-2018 12:06 PM
ProTools Not Connecting to Artist Mix MicMan Artist Series 2 01-02-2018 03:37 PM
Artist Control controlling other things Neale Artist Series 11 10-20-2016 07:19 AM
Controlling plug-ins with Avid Artist Mix + Control ryanstewartguitar Artist Series 2 11-07-2013 01:07 AM
