Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 07-19-2021, 01:27 PM
dg27's Avatar
dg27 dg27 is offline
Default Re: PT unable to require hardware
Originally Posted by EGS View Post
I doubt it has anything at all to do with which build of Windows you are using.
Thanks again for all your help. The reason I suggested Build 2004 could be at least part of the issue is that since I updated from Build 1909 Microsoft Explorer loads VERY slowly. Under 1909 I never saw the status bar progressing at the top.
Be Quiet Pure Base 600 case * Core i5-12600K * Gigabyte Z690 UD AX * 32 GB G.Skill Ripjaws DDR4 * 2X HP DreamColor Z24x G2 displays * NVIDIA GeForce GTX 960 * Samsung 980 boot drive * Samsung 870 EVO PT projects drive * Samsung 860 EVO PT archive drive * Novation Impulse 49 MIDI * PreSonus Studio 26c interface * PreSonus Bluetube V2 preamp * PreSonus HP4 headphone amp * JBL LR 305 monitors * Sennheiser HD 650 headphones *
Windows 10 Pro 64 21H2, Pro Tools 2022.7.0
Old 07-19-2021, 02:06 PM
EGS's Avatar
EGS EGS is offline
Originally Posted by dg27 View Post
... Microsoft Explorer loads VERY slowly...
This? https://windowsreport.com/file-explo...ave%20changes.
Click for audio/video demo
Click for resume
Old 07-19-2021, 02:28 PM
EGS's Avatar
EGS EGS is offline
...3rd party plugins in a separate folder? ... CCleaner for years, but it's gotten a very bad rep ...
To troubleshoot, I'd actually un-install all 3rd party plugs, run CCleaner free version reg & clean passes, and reboot.
Click for resume
Old 07-19-2021, 05:13 PM
dg27's Avatar
Thanks--this really useful. I already had Cortana disabled, plus a lot of the other tweaks in place, but Windows Search was indeed running and I disabled it.
Will have to go thru the rest.
I did run CC reg and clean passes.
I uninstalled PT 2020.12; will try again. Not thrilled with uninstalling/reinstalling 3rd-party PIs, but if that's what it takes...
Thanks again.
Old 07-20-2021, 06:55 AM
dg27's Avatar
I'm convinced that the difficulties I'm facing are related to Windows 10 rather than PT. (The slow green progress bar in Windows Explorer is what leads ne to believe that something is amiss.)
I've gone through all the recommendations at the links above to no avail. (Most of these were already in place, since they're part of my normal tweaks.)
I'm not going to reinstall any PT version until I've sorted out the Windows issues.
  #16
Old 07-20-2021, 07:02 AM
EGS's Avatar
EGS EGS is offline
... slow green progress bar in Windows Explorer ...
Google search: "slow green progress bar in Windows Explorer".
Click for resume
  #17
Old 07-20-2021, 09:28 AM
dg27's Avatar
I did that and performed all the recommended tests and tweaks.
Also:
Ran sfc: no violations.
Ran Repair-Windows Image: Healthy.
Ran a diagnostic memory test: passed
I changed the folder options to show icons rather than thumbnails and that had no effect. (I leave it set to display thumbnails because I regularly need to browse my own photos related to writing I do for my own work.)
Another symptom of the strange behavior is that when I open a folder that contains images, the thumbnails take a long time to load: They appear as low res and then gradually come into focus. I've never seen this before.
  #18
Old 07-20-2021, 10:01 AM
EGS's Avatar
EGS EGS is offline
I did that and performed all the recommended tests and tweaks...
ALL? Really? Then roll-back to a known-working boot drive image. If you don't have an image, then clean install of Windows.
Click for resume
  #19
Old 07-20-2021, 11:05 AM
dg27's Avatar
Yes--Most of the changes to settings were already my defaults.
I run Acronis every day and will use one of those backups as a last resort.
One thought: I upgraded to Build 2004 after applying many updates to 1909 (all in the same update session). I'm tempted to roll back to 1909, see if everything is normal, and then update to 2004.
Doing a clean install and getting all of the associated programs installed (95 + another 60 related to Pro Tools) and the OS tweaked generally takes about a week, which I cannot do at this time due to work commitments: I can't take my system off line even for one day.
This is why I'm focusing on fixing this rather than starting from scratch. Things work, but not as they should.
Thanks for your help.
  #20
Old 07-20-2021, 11:53 AM
EGS's Avatar
EGS EGS is offline
... will use one of those backups as a last resort...
That's the FIRST thing to do. 20min fix.
Click for resume
What versions of ProTools do NOT require m-audio hardware? importztek General Discussion 13 01-06-2013 08:51 AM
"Unable to locate M-Audio hardware. Make sure your hardware is connected and turned o MerryD Pro Tools SE and Essential (Win) 8 08-02-2012 12:59 AM
unable to locate m-audio hardware. make sure your hardware is..works fine in ableton? pein Pro Tools M-Powered (Win) 2 10-07-2009 12:01 AM
...unable to require m-audio harware... gwiedo Pro Tools M-Powered (Win) 1 05-08-2005 04:50 PM
PT vs programs which don't require their hardware sndchck 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-20-2005 01:32 PM
