Re: Help! ProTools 5.1.3 on MacOS 9
Good news then, we have a plan B
This is literally his life's work hanging in the balance, unfortunately. I wonder what it would cost to ship that across the ocean? Probably an additional $300 or so I would imagine? |
That is great news and an excellent plan B.
For the record I do have a G4 PowerMac with MIX3, but it is on another location and cannot test anything for you. All I am telling you comes from memory.
That makes sense. I would imagine that would be the case. I'll see what we can figure out with DigiTest today. And that makes sense about the Extensions Manager. |
#16
Also, for your troubleshooting:
Pressing 'space' key at startup will allow you to select/deselect extensions/control panels in Extension Manager.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
#17
I really everyone's help so far. |
#18
More stuff that might help:
1-shut down the rig, open it and reseat any/all the cards 2-reseat all connections between the card(s) and any interfaces 3-On any Mac, PT versions 6 thru 10 should open any of his sessions(even the LE version will open the sessions). 4-once a session is open, its crucial that he go to File>Save Copy In> and do 2 things; #1-check the box to enforce PC/Mac compatibility, and #2-save to wave format(if possible, aiff if not). Doing this will allow the sessions to open on any current PT system, even Windows-based) 5-while he has a session open, he should also consolidate all audio back to zero and then export the consolidated audio files to another folder for each song. This way, these files can be imported into any DAW on any platform 6-just an FYI for him; some plugins(even stock ones) may not be available on newer systems, but he should not have any issues finding a newer replacement
#19
This is very optional, and can be done anytime if/when needed.
#20
If we get this system up and running, the plan is to export zero-index exports of every track in every session. I think this is (hopefully) the final wake-up call he needs to finally migrate away. That's excellent to know about the "PC/Mac Compatibility" checkbox. I think he's mainly using really olde versions of the Waves/Renaissance plugins from that vintage. So, we should be able to get those running on newer software also. I'd probably try and steer him towards other plugins, but if he insists, they're available. |
ProTools 6.4 LE on MacOS 10.3.6? | robert_kennedy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-08-2004 02:43 PM |
Protools and MacOs X | Morado | Pro Tools TDM Systems (Mac) | 8 | 12-14-2001 07:18 AM |
Protools and MacOs X, When? | Samuelsson | Pro Tools TDM Systems (Mac) | 0 | 10-30-2001 09:43 AM |
ProTools and MacOs X? | Samuelsson | Digidesign Hardware & Software | 0 | 10-23-2001 09:31 AM |
MacOS freezes ±30s. under ProTools !! | Lo | Pro Tools TDM Systems (Mac) | 7 | 11-01-1999 06:20 PM |
