Old 05-12-2021, 10:44 AM
bifbangpow bifbangpow is offline
Default How to use mod wheel in Play
I'm using Play AAX for some eastwest plugins. I'd like to attach my mod wheel on my m audio keystation to control expression. Can someone help me do this?
my specs:
iMac 2020
3.8Ghz 8-core Intel core i7 processor
Catalina OS
ProTools 2020.12
Scarlett Focusrite
+ Saving to External Harddrive
http://MayMcDonoughMusic.com
Old 05-13-2021, 03:57 AM
Default Re: How to use mod wheel in Play
You'd have to find some way to map what the mod wheel sends to CC11. Unfortunately there's no way to MIDI learn a control for that as there's no slider/knob for expression in Play. Play used to use (may still do) CC11 as a volume control. When I use Play libraries I map the volume slider for each part to what my keyboard controller sends from the attached volume pedal which is cc7.
Do you really need expression (CC11) or volume (CC7)? They're two different animals.
Keep in mind that I only use older EW libraries like Symphonic Orchestra, Ra and Stormdrum and don't know what changes may have been made to the engine with regards to newer libraries.
Jack
QAPLA!
Last edited by musicman691; 05-13-2021 at 04:08 AM. Reason: massive changes to original
Old 05-13-2021, 12:39 PM
I'm trying to work on getting more realistic sounding orchestration. crescendos and decrescendos etc.
my specs:
iMac 2020
Catalina OS
ProTools 2020.12
Scarlett Focusrite
Old 05-13-2021, 12:56 PM
You may want to ask about this over on the EW forums. But like I said there's no programmable controller on the Play engine that will do CC11 (expression) even though the engine & libraries can respond to CC11.
Jack
QAPLA!
PT12.6 won't play sessions. They load ok, but when I press play nothing happens senghor Pro Tools 12 1 12-30-2016 07:43 PM
PT12.6.1 won't play sessions. They load ok, but when I press play nothing happens senghor Pro Tools 12 5 12-11-2016 10:30 PM
Notation view edit while in play cause play to stop working. soybalm Pro Tools 10 1 04-18-2013 11:11 AM
spinning wheel (freeze) when pressing play anricat Pro Tools M-Powered (Mac) 0 10-01-2009 03:46 PM
Scrub Wheel or Jog Wheel for PT JaredC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 05-07-2004 06:01 PM
