PT8, Sustain pedal, velocity problems while recording
Hi, I´ve trouble, while recording MIDI in PT8.. doesn´t matter if virtual Instruments or real MIDI Outboard Gear...
I use MacPro, Unitor 8 Mk2, 2 Amt 8s, connected as one big machine 24 MIDI I/O.. While playing along the PT Session, everythings´s fine, just when I record: I get cutted sustain pedals, Velocity seems also sometines sound strange to me..but the worst is the Ctrl 64 (sustain). Doen´t matter if my MasterKeyboard is connected via USB or MIDI...I also checked with several Keys....same problem... Anyone an idea?? Hope to read from you... Chris |
Re: PT8, Sustain pedal, velocity problems while recording
Make sure your keyboard isn't set to use multiple zones, then go to Preferences>MIDI in Pro Tools and try changing the default midi thru instrument to either the first MIDI port for your keyboard or to first active MIDI track - one of those settings should fix the problem.
Problems with MIDI Sustain Pedal while recording | ChrisSimon | Pro Tools TDM Systems (Mac) | 71 | 06-25-2014 11:30 AM |
Sustain Pedal Problems while rec. HORROR!!!! | ChrisSimon | MIDI | 2 | 12-10-2009 03:09 AM |
sustain pedal problems in 6.4LE | tromostheory | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-29-2009 10:24 AM |
Piano sustain pedal in recording Help!! | Zownd | Tips & Tricks | 9 | 04-05-2004 03:21 PM |
Sustain Pedal in Midi recording in PT LE | Arya44 | Tips & Tricks | 1 | 11-10-2003 12:25 AM |
