Old 06-23-2002, 03:42 PM
Bastiaan Bastiaan is offline
Default Re: high pitched unexplicable "whine" in ProTools
must be a protools thing, not a mac/mbox thing. I experienced that once....and i run ptle with a pc and a digi001. The screaming only stopped when i quit ptle.....and i did a cold reboot to be sure. It never happened again....scared the living daylights out of me.....
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 06-23-2002, 04:08 PM
Slim Shady Slim Shady is offline
It didn't sound like the screaming-blow-yer-brains-out-lie-bleeding-on-the-floor noise that has plauged others. He just described it as a whine, which is pretty tame compared to the sound I think you're referring to, that's why I suggested an OS/software problem.
phunk1, can you describe the noise more in depth?
Old 06-23-2002, 04:15 PM
phunk1 phunk1 is offline
It is a lite-scream, and its only audible when I crank the volume on the MBOx headphone jack all the way up. Its barely audible in my monitors(Mbox>Behringer mixer>Alesis Amp>Event monitors) even when the mixer main volume is *cranked*. The suggestion to upgrade to 9.2.2 is a good one, and one I expected, but I'm recording at the moment, and in 40 minutes, I'm going to try the upgrade. I just wanted to make sure it wasn't somthing simple that someone had already dealt with before I went to an upgrade of the OS. Do you guys have any tips on the upgrade to make it go smoother? Thanks for your thoughts so far...
Old 06-23-2002, 04:19 PM
cecilsound cecilsound is offline
Not familiar with the MBox, but you could check that your hardware is set to internal sync in the "Hardware" menu. My older PT system used to make that noise when it launched and had been switched (how, I don't know) to external sync with no other hardware to sync to. May not be the cause but worth checking.
Old 06-23-2002, 04:23 PM
I checked my sync-mode, and it was "S/PDIF", but when I changed it to internal, the "whine" remained.
thanks,
g
Old 06-23-2002, 05:32 PM
shaggy shaggy is offline
Any other USB devices?
I'm guessing maybe a voltage problem.
"The original nipper" Throw me a bone (Telefunken DI is ok too)
Old 06-23-2002, 05:36 PM
ok.......another idea......are you using the supplied usb-cable?
I've seen posts of people who used different cables and got some interference from crt's, and the computer itself. Try relocating the usb-cable.......
What's that?
Bastiaan
Old 06-23-2002, 05:38 PM
theom theom is offline
I feel like i remember an issue with the internal modem. that was with 001 though.
try disabling the internal modem extentions , or in control panels set the modem sound to off.
a shot in the dark.
Old 06-23-2002, 09:51 PM
John J. John J. is offline
another shot in the dark...
Although you haven't mentioned any external scsi or firewire drives for your audio, after daisy-chaining 2 new 120 gig IBM drives (ADS Pyro cases) with my 2 x 75 gig IBM drives(ADS Pyro cases) I immediately encountered a high-pitched whine through my main stereo bus. Somewhere in the 10-16K frequency.
After trying various fixes, it came down to my new daisy-chain connections (FW cable) to the additional drives. Hotswapping-then-unplugging the new drives from the older immediately solved the problem.
Grounding? Bad cable or cases? I'll hopefully have time to nail this week. Good luck!
MacPro 2.66 8 core • 24G ram • Lotsa Terrabytes
OSX 10.8.4 • MBP Core i7
C|24 • PT 10/11 HD • Reason 6
www.icedrum.com
Old 06-23-2002, 09:59 PM
Percustard Percustard is offline
Maybe it is the sound of the DUC in the background ;-}
High-pitched whine in right speaker! The Mink 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-23-2012 11:28 AM
High pitched whine GlenHarness 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-24-2006 05:38 PM
HPF = high pitched whine Chris Coleman Pro Tools TDM Systems (Mac) 4 02-23-2006 09:53 AM
high pitched whine clay19 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-08-2004 01:48 PM
High pitched feedback...also previously referred to as "the explosion"... Ben Jenssen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-20-2002 01:31 PM
