Got one! Couple major issues so for - need suggestions, please
So, about every other time I reboot of the Mac Carbon defaults back to 44.1 instead of 48. This also crashes Pro Tools when trying to open it, which is when I realize the issue occurred. Last open session was 48. However, I switch sample rates quite a bit between 44 and 48 for projects I work with, so this is difficult.
Bigger issue, though, is ADAT sync stops sporadically and I get an error about clock. Clocking from Apogee Symphony I/O. If I go to the Audio MIDI app and toggle it from ADAT to ADAT it works again. This is obviously an issue. Quality ADAT cables are used. I get no issues showing on the Apogee and signal still seems to work as normal, but recording stops due to no clock. Ideas? I also get an error during session that there's too little DSP to do routing. Simple session with 25 tracks and 12 auxes. Most have HP1-4 until I get the error that some are disabled from too little DSP. About half the DSP is plugins. The other 4 are Mixer. |
Re: Got one! Couple major issues so for - need suggestions, please
Not dismissing the original issue but, have you tried clocking the Carbon from the Symphony using word clock instead of ADAT?
https://lukehoward.com/ |
Setting clocking from the Audio MIDI app feels really wonky. And seems to work that way too. |
Plan B might be better anyway as, less jitter in WC vs ADAT.
Support emailed me and had suggestions. I ended up using a different mac and didn't have issues with adat clocking from that point on. Used on sessions for a few days without any issues.
A couple of issues with PT 9HD | SteveGarman | Pro Tools TDM Systems (Mac) | 2 | 03-09-2012 01:08 PM |
Couple of suggestions for D-Control design | MikeOlson | ICON & C|24 | 4 | 09-07-2007 09:13 AM |
Major Stability issues - need help and suggestions | truenorthrob | Pro Tools M-Powered (Win) | 4 | 11-16-2006 08:51 PM |
major, major issues | satchvai | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 02-03-2006 12:10 PM |
A couple of suggestions for the new DUC software | RobMacki | General Discussion | 12 | 09-16-2003 10:38 PM |
