#21
Re: S1/DOCK/Control loose connection every now and then...
...yes, today without tablet, when I reordered some tracks, all surfaces lost their fixed track-layout. I could recall that layout, but I wonder why that happens.
Best Maik
PT HDN 2024.3, OMNI, SYNC HD, Dock, 2xS1, PT Control, MacPro 5,1 12core 48GB, OSX 12.7.4, BM Decklink Extreme 3D ------------ mars13.de |
#22
I'm not understanding I think. On the assign tab in EuControl is your DAW locked?
#23
Eucon is locked to Pro Tools.
No control app involved. But from time to time, the surfaces loose their assignments, sometimes they reboot. Best Maik
#24
This is not normal or often posted about. When you say they reboot, do you seethe green flashing lights on the S1's?
#25
Hi Eddie,
can't say anything about the green lights. It didn't happen the last few days. They seem to do this, when the network connection is changed or lost. I made a new second installation on one system with macOS 10.15.7. First eucon seemed to be more stable. But then in the middle of a Mixsession with client, all the units lost their assignments, came back, recalled layout, lost it again after a few seconds, came back... This happened about three times in maybe 5 minutes. After that it worked till the end of the day. I hope the next version of eucon is much more stable, because I'm in trouble and have no idea what to do next. Best Maik
#26
I just wanted to tell you that I had success with a simple USB3 to Gigabit LAN Adapter. Eucon is stable since I connected with this Adapter. Cheers Maik
#27
I was going to start a new thread but this seems to fit in this thread so...
My current setup is the S1 and the app, all connected to their dedicated router and the connection is solid. However, every few hours or so I find that the functions I assigned in the S1 switches stop working. Faders are all good, writing automation and display... everything is fine. It's just the shortcuts in the S1 bottom switches. So I need to restart the Eucon application and then they work again. Very annoying! To the point where I just stopped using it altogether... |
#28
If the disconnect happens at a regular interval, it could be a program on the computer that is "phoning home" and momentarily hogging the network connection.
#29
Interesting.
Is there any way to check if that's the case on a mac? Like, if I notice I get this kind of behaviour to see what's "hogging" the connection? |
#30
When his happens again, without focusing on any other App can you open EuControl and go to the Softkey tab. What does it say is the Application.
Recommended ethernet switch for Artist and Dock Connection | sjgam | Artist Series | 5 | 10-19-2018 09:09 AM |
Control App with Dock Connection Question | sjgam | Avid S1, S3, Dock and Control App | 1 | 10-19-2018 08:12 AM |
Some Faders or Buttons Randomly Loose Connection | Barry Johns | ProControl, Control|24, Command|8 | 1 | 06-14-2014 01:40 PM |
MBOX 2 USB connection Loose! help | mfaktr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-06-2008 12:04 PM |
Orig MBox Loose USB Connection. Any Suggestions? | Matt Foglia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-22-2007 12:00 PM |
