Old 12-06-2016, 10:33 PM
Base12 Base12 is offline
Default Bug? No session conversion unless logged in
A few weeks ago the Avid servers were down and I was unable to login within Windows PT HD 12.6 or the Application manager. I only work with local sessions, no online projects. I decided to open an old session I had from 6.4 LE As expected, PT offered to convert the session so I can use it in my HD. I've done this many times without problems. This time though, when I went to open the old PT 6 file, the HD system said I had exhausted my project limit and that I should delete some online projects to make room. I was not using the project, I was using local session. I ended up not able to work on the old session for over 12 hours until the servers came back online. Once I logged in, PT converted my local session and I saved it on my hard drive with none of the warnings/blocking displaying anymore.
Is this a bug? Why should I have to login online to open an old PT 6 session song and convert it to the new 12.6 format? This means if my internet is ever down, I am unable to convert old local sessions to new the version. Is this the expected logic in PT HD for this type of processing or is this a bug?
Tx
Old 12-07-2016, 05:40 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Bug? No session conversion unless logged in
Try uninstalling Avid App Manager and Cloud Collaboration.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 12-13-2016, 09:54 PM
I'll try that thanks
getting logged out of DUC? musicman691 General Discussion 4 08-11-2014 10:42 AM
Pro Tools session conversion help! jv2612 macOS 2 02-03-2013 07:03 PM
Mac session to PC conversion? idkmybffjill 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-20-2008 12:45 PM
DUC running slow when logged in...? mtung General Discussion 10 04-26-2007 12:43 AM
96k to 48k session conversion donrey Pro Tools TDM Systems (Mac) 6 10-31-2006 03:20 PM
