Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 08-17-2011, 04:45 AM
RJRuss RJRuss is offline
Default Pro Tools Interface
I have asked Avid, maybe if I am correct you may too. ProTools interface is slick and easy to use... but ... IF you edit voice tracks for a living would these 2 things make life much more simple?
1. In the blank bar above the SEC:MIN could that space hold Pre-Sets for the Audio Suite options we use most frequently? The time consumption of Clicking the drop down box and scrolling for the Plug-in you need would be eliminated.
2. Allow a working Pre-Set for both The Gain and Normalize. Having to adjust them every time you need them, again, is Time Consuming.
When doing Voice Tracks eliminating breaths, "wet mouth" clicks and pops and other innocuous noises, editing and processing adds so much more time than just clicking a designated Pre-Set ON the interface would.
You thoughts?
Old 08-17-2011, 10:27 AM
Craig F Craig F is offline
Default Re: Pro Tools Interface
http://protools.ideascale.com/
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 08-17-2011, 01:56 PM
The Weed's Avatar
The Weed The Weed is offline
Ctrl or Command Click on the plug-in name and it will be a "Favorite" when you open the AudioSuite Menu. Same thing if you Ctrl or Command Click on an RTAS plug-in name, you can have "Favorites" on the Insert menu.
Cheers,
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 08-17-2011, 02:33 PM
Stig Eliassen's Avatar
I have shortcuts made in the OS X system prefs for AS plugins. Ctrl+G is Gain, Ctrl+R is Reverse, Ctrl+V is Vari-Fi, and so on.
how use pro tools without interface pinnacle Pro Tools 10 12 10-09-2013 05:49 PM
pro tools 10 and interface randyhill87 Windows 8 04-22-2012 02:07 PM
Best interface for pro tools hd Raoul23 Pro Tools TDM Systems (Win) 2 09-26-2010 05:08 PM
Pro Tools Interface c0m3t0g3th3r Pro Tools M-Powered (Mac) 7 11-29-2009 07:24 PM
Pro Tools and PC Interface sabluka General Discussion 1 05-07-2007 04:28 PM
